WSea
- First Name
- Patrick
- Joined
- Mar 6, 2022
- Threads
- 39
- Messages
- 1,589
- Reaction score
- 1,898
- Location
- West seattle
- Vehicles
- R1T, Outback
- Occupation
- Architect
Do you think that’s causing the noise? Could you link that online info? ThanksMakes sense. I don't mean they don't know how to fix vehicles. Just that until central command tells them to look at things, they don't even know to look. Mine went into a service center for noisy suspension and came back still noisy. A bit of time passes and I see pictures of Rivians online with the upper ball joint separated from upper control arms. I go check mine and they are about finger tight. So clearly went in for suspension noise concern and came back same....with loose upper balljoints.
Not blaming the techs...they had no idea what to look for and have been lead to believe noisy front ends (or have concluded) noisy front ends are normal.
But central command I am sure sees these concerns and at some point it should raise their concern and then dig in and find root cause and deploy solution to service centers.
