Adjust tailgate cables?
Oldsmobile_Mike
Manassas Park, VA
FG/FE R1T recv'd 3/31/2023
I build stuff
In one of the (thankfully) few issues I've discovered with my R1T, the tailgate cables are out of adjustment. The passenger side cable is taut but the driver's side just flops around. Video:
It looks like the top end of the cable disappears behind the plastic insert in the bed. Is this something that a person can adjust themself or would it require a service visit? Or maybe they'd just mail me new cables. Anyone fixed this before?
WattTruckMatt
Austin
2022 Rivian R1T
Mine does the exact same. They’re both taut when you put weight on the tailgate. If there’s an easy way to adjust them I’ll happily do it.
goldburger
I had a service ticket for this and he said three things: they are redesigning the cables, the cables don’t actually act as the support for the tailgate it’s all in the hinges, and this is normal and every truck on the lot has the same thing. So they didn’t repair it.
I took my cables off as an experiment and the hinges are definitely not self supporting as the tailgate continued to deflect under slight load. I was thinking about removing them so they wouldn't interfere with drawers coming sideways out of a bed slide. Definitely not an option IMO.
LevelHeaded
WA, USA
R1T QM
Financial Technology
My R1T (took delivery on Tuesday) has the same issue. Driver’s side is loose. I can tell the cables DO support the tailgate, for sure. I can tell the driver’s side gives more than the passenger’s under just the weight of me pushing on it.
Makes me nervous to put any weight on the tailgate — it would effectively cause it to twist slightly, since one side is held tighter.
Rivian R1T, 2024 BMW i4 M50
I haven't even noticed but I have put plenty of weight on the tailgate many times and I haven't had any issues with it.
Christopher
Christopher
South Florida
Tech
My previous pickup had the same "issue". Every other truck on the lot also did.
RabidRat
NorCal
22 R1T, 03 S2K
I also filed a ticket for it and was also told by the SC that it was normal, that the cables are redundant, and they were not going to fix it.
I too, would love to be able to adjust it myself.
Christopher
Christopher
South Florida
Tech
Really? I’ve never seen it before on previous trucks.
Yup, on my Silverado and when I went to get it fixed they welcomed me to look at other trucks on the lot and they all had slack in either one of the cables. Had it for 4 years like this and never ran into any issues. And when you put a lot of weight on the tailgate it would flex and both cables would receive the weight so really wasn't a problem.
LevelHeaded
WA, USA
R1T QM
Got it. I’d have assumed that were the case if there were less slack, was just surprised with the amount. The driver’s corner of the tailgate would have to be pushed a couple inches lower than the other for both to be taut.
madgrey
Allan
Fidalgo Island, WA
Hardware Design Verification
I had not seen this type of issue on previous trucks I've owned (2 RAMs, a Ford and a Toyota). But on my R1T, it was pretty bad. One cable had quite a bit of play and it didn't seem like there was any way to adjust it. The SC replaced the cable back in January, which improved things but didn't really "fix" it.
LevelHeaded
WA, USA
R1T QM
If I sit on it, they do even out so… as long as that isn’t warping the door over time! I attempted to measure the cables and I believe the longer one is ~ 1/4” longer or so
