Rivian posted their installation guide for the wall charger:
PDF download
DucRider
Gary
ORegon
Polestar 2, Ioniq, R1S
Hardwired only (likely to meet NEC requirements)
As a plug-in, it would not meet the requirement prohibiting adjustable amperages, and is not set up for tool free removal (also required).
They did comply with the requirement for restricted access to the amperage settings (dip switches in this case).
jjswan33
Joshua
Sandy, OR
Interesting that they suggest 6 awg wire is sufficient for the full 60A circuit setting, I guess since it only pulls 48A that is ok? I was under the impression that a 60A circuit would need 4 awg wiring.
kommonplace
Kevin
Bardstown, KY, USA
www.kevinjwangler.com
2014 Ford Flex, non-LE R1S preorder
IT Director
How easy would it be to replace a Tesla Wall Charger (hardwired) with one of these guys? For someone who typically doesn't mess with electricity.
SeaGeo
Brice
Xc60 T8
easy peezy as long as you know how to turn off your circuit breaker.
kommonplace
Kevin
Bardstown, KY, USA
IT Director
Now THAT I can do! I read the guide (honestly, Rivian could publish just about any piece of information and I'd read it) and it looked.... very easy. Just wanted to make sure it was as easy as it looked. Thank you!
Not difficult but if you are not familiar with doing electrical fixtures may not want to start here.
With the amount of amps being pulled if the wires are not seated and torqued properly they could generate excessive heat. You also have to look at the wires and breakers installed to ensure you set the dip switches for the proper draw.
DucRider
Gary
ORegon
6 awg is fine as long as it is 90° rated
If thinking of using NM-B (Romex), it is not OK as it requires using the 60° column/rating
kommonplace
Kevin
Bardstown, KY, USA
IT Director
It's a 60A breaker so I believe I'd be leaving it at the default settings on the dip switches.
The torque part, I had planned on "okay, that feels tight enough" but your comment is making me think that is not going to cut it. My wife said "get whatever you need" ... until we saw the prices on those guys. Sheesh. No wonder I don't own one!
Thanks for your reply—very helpful.
lefkonj
Jeff
New Jersey
Gen2 R1S Tri, I4-m50
I thought their charger was Nema 14-50 or Hardwired. These docs say hardwired only or am I wrong? That sucks
timesinks
R1T, ID.4, Sprinter
The portable one that comes with the vehicle will be plug and cord. The wall charger will be hardwire.
Amy
Amy
Dallas,TX
2022 E-Tron Sportback
Like said before, do not start here. High Amps can be a major fire hazard if you don't tighten thing down and strip wires wrong.
crashmtb
Man oh Manitoba
simply apply money - call an electrician!
Ssaehrig
Steven
CT
2018 Durango SRT, 2013 GMC Acadia
IT Executive
I am going with the higher capacity wire. No need to stress the wiring.
