Rivian_Hugh_III
Midwest
2008 Infiniti EX35
Of? I attached a picture of the powder coated bracket. There's a video in the OG post of the install, and on the website has pictures of them installed on my truck.
The one you mention that is not here is the picture of them installed in the truck. So yeah, that one. Or not, whatev.
Sojhinn
Sojhinn
2019 Tacoma
Teacher
I just realized my comment may have came across snarky. That was not intentional. I'm sorry if it came across that way. I genuinely just wanted to know which picture you wanted.
Rivian_Hugh_III
Midwest
2008 Infiniti EX35
Same here. Sorry for that. I appreciate the great work you’re doing and offering to the community.
zonehawk
200 Series Land Cruiser, R1T Adventure FG (Sold)
Just received mine, it looks like it came with two foam squares with adhesive, is there a particular place those should be applied too?
Sojhinn
Sojhinn
2019 Tacoma
Teacher
Are they not stuck on? If not: while lining up your bracket you want it to line up with the edge of hood bracket. (Closest to the windshield)
Wrinks
R1T, Polestar 2
Button Pusher
Yeah...I didn't attach the last couple because I wasn't sure exactly how they should be positioned. I saw how the install went on another persons' and where I thought it should go didn't do anything for them. Will do some more testing and learning to figure out where to apply them when NOT on the truck. Easy to do once it's on and not fully tightened down =)
SPITmadFIRE
2024 R1S PDM Max Pack 20" AT
Howdy! are these still being made? I saw the back order notice on the site mentions production beginning around Christmas but don't see any updates.
also, what's the size of the hole for mounting the light bracket to? I'm curious if an NMO antenna mount will fit easily without modification, or if it can be predrilled to the right size.
Sojhinn
Sojhinn
2019 Tacoma
Teacher
They should be available again. They got backordered over Christmas.
We have someone using them as an antenna mount, I have to double check the size of the boot hole but it fits the 4 banger bolt so that should help.
Wrinks
R1T, Polestar 2
Button Pusher
Just to confirm what @Sojhinn said - I got the new sets counted in to inventory this morning and added back up to the site!
https://s00nish.com/products/s00nish-ditch-light-bracket-for-rivian-r1t-r1s
Let me know if you've any issues with the order =)
SPITmadFIRE
Sojhinn
Sojhinn
2019 Tacoma
Teacher
Thank you! I don't see any images of what the mounting hole itself looks like, but if you have dimensions and it works for a standard NMO antenna mount (3/4" hole) I'll buy one right away!
It's 11 mm in diameter, so a lot smaller than 3/4"
SPITmadFIRE
Got it -- that's a bummer for my use case. If you consider doing a run of NMO antenna mount brackets you've got at least one guaranteed sale ?
Tr4ckD4ys
Noneya, NY
@Sojhinn what happened to those a pillar brackets? I no longer seem then on the site?
Sojhinn
Sojhinn
2019 Tacoma
Teacher
A pillar brackets? I haven't had any. We did look into using a bolt that held the front quarter panel. But I didn't like the way it pushed a lot of the rubber around at that location.
