Deadfish
- First Name
- Erik
- Joined
- Apr 21, 2023
- Threads
- 5
- Messages
- 33
- Reaction score
- 22
- Location
- Vancouver BC
- Vehicles
- 2023 - R1S
- Occupation
- Computer Consultant
- Thread starter
- #1
So far this is what I have figured out about PaaK:
1. The Rivian has multi-Bluetooth sensors around the truck, and inside.
2. To unlock, is more than a Bluetooth connection - there is some exchange at a software level.
3. When you approach the Truck, if the Bluetooth handshake works - the brake lights flash to show you are linked. (fob does this too)
4. The unlock seems to be trigged by Bluetooth connecting reaching a certain signal strength.
So there seems to be 3 main problems:
1. Some phones seem to sleep the software, and the handshake does not happen (Handshake problem)
2. As you get close enough, the truck delays the un-lock even when you are in range (Unlock Delay)
3. The signal strength required to unlock needs you to lift the phone right next to the windows. (Signal strength)
Issues 2 and 3 can also happen with the Key Fob.
Issue 1 seems to be solved (temp) by restarting the phone / airplane mode / cycling Bluetooth - This issue could be phone / app / or Rivian problem.
Issue 2 and 3 are Rivian software problems that they can fix with software changed in the truck.
Open to any other input, as for things I've missed. But I think if we express our issues broken out as the 3 above, we'll be able to move close to a solution. Even my service rep had not heard of the separate issues (just treated them all as one).
