Front End Air Suspension FAIL
cklighty
Kevin
Santa Monica
Launch R1T
I love my Gen 1 R1T - 573rd off the production line, BUT I'm starting to have buyers remorse as our truck is currently in El Segundo SC for the 3rd time this past year and my comprehensive warranty coverage is only valid for the remainder of this year, 2026. This time the air suspension in the front got stuck in its lowest position, resting on the bumper stops, rendering the truck inoperable and unsafe to drive. We had to call roadside and have it towed on a flatbed to the SC. The fail started immediately after exiting service mode. The truck had been sitting idle in our driveway for several days. I had put it into service mode and pulled up the RIDE menu to check the 12v battery health. 12v looked good. We have only 17k miles on the truck. Upon exiting service mode, the front end lowered all the way down and could not lift itself back up again. We tried going a short distance, as recommended after the truck has been placed in 'kneel' mode, but that did nothing. When waking the truck from sleep, the air compressors work overtime to inflate the front until they shutdown with a 'suspension needs to cool' error message on the small screen. I know that both the towing and the repair should be covered under the comprehensive part of our warranty. However, when I pointed out that one of the inner wheel well covers had been jarred out of position, the tech receiving the truck told me that would fall under the 'adjustment warranty coverage', which had long since expired. Seems like that is a direct result of the front end being grounded and should therefore be included under the comprehensive coverage. Anyway,... has anyone else heard of this front end suspension fail? We were already aware of the top 3 Gen1 quirks; (1) 12v battery, (2) tonneau cover, (3) front suspension rocker arms, but this is the first we've come across this air suspension fail, resulting in the front end of the truck being grounded.
Ecupip
NC
Rivian, Audi, and 2 Jeeps
You need to inform them the adjustment warranty ends with the basic 5/60 period on yours. The shortened adjustment warranty doesn’t apply to any 2022 models.
MadMen
Nick
Mooresville, NC
2022 Rivian R1T Adventure
Hmm. This isn't true on my '22. I had Rivian send me my warranty status a few weeks ago, and the fit/finish warranty expired at 1 year.
Active warranties
  • Comprehensive Limited Warranty: active through July 30, 2027 or 60,000 miles, whichever comes first
  • Drivetrain Limited Warranty: active through July 30, 2030 or 175,000 miles, whichever comes first
  • High Voltage Battery Pack Limited Warranty: active through July 30, 2030 or 175,000 miles, whichever comes first
  • Occupant Active Restraint System Limited Warranty: active through July 30, 2030 or 100,000 miles, whichever comes first
  • Corrosion (Perforation Only) Limited Warranty: active through July 30, 2030 with unlimited miles
Expired warranties
  • Adjustment Limited Warranty: expired July 30, 2023
  • 12 Volt Battery Limited Warranty: expired July 30, 2025
  • Exterior Surface Rust Limited Warranty: expired July 30, 2025
RBM3
Jon
eGolf, GX460
Active warranties
Expired warranties
Check this post.
https://www.rivianforums.com/forum/threads/adjustment-warranty.17692/post-374666
There’s a link to the original warranty terms. And it shows that those terms changed June 2023. So if you bought your R1 before then, the limit of 1 year on the adjustment warranty doesn’t apply to you. They can’t change your warranty after you bought your car, even if their system says that it’s expired.
If you read the verbiage in the pdf for the 5yr/60k Comprehensive Warranty it states it covers adjustments.
MadMen
Nick
Mooresville, NC
They are incorrect then. Here is the warranty guide based on the effective date. Choose the one that matches your build date. I'm guessing that it is June 2022 and that the guide has no specific adjustment period.
https://rivian.com/support/article/new-vehicle-limited-warranty-guide
Very interesting. So by that logic, my fit/adjustment warranty should be forever? I do have a few trim fit issues on the body that I may have them look at next visit then :)
Although since it doesn't bother me too much, I'll probably leave it be since I just know when they fix that, something else will go wrong immediately after....
But interested to see what the OP is able to get from them since we fall within the same timeframe for warranty.....
RBM3
Jon
eGolf, GX460
Adjustments are listed as part of the 5yr/60k mile Comprehensive warranty before the change in June 2023
Rivian Owner
Pacific North West
1971 GTO, 2019 F150,
Ah! So I need to let the Rivian person that sent me that email know they were incorrect. Thanks!
Based on your comment, diplomacy is important as well as what the warranty says. I'm not sure I'd approach the "Rivian person" with "you were incorrect", but perhaps, suggest that they may not be aware of the earlier warranty terms that weren't changed by the Rivian change at a later date and allow them to explain their view point? I think if you present the information in an informative way and ask for their input, rather than a confrontational approach, you'll get a lot more cooperation.
MadMen
Nick
Mooresville, NC
Yep - I would be very polite about it. Just an honest mistake.
My other thought is, and I didn't read the whole document (I'll have to load it to AI and ask it to find the answer), perhaps that part of the warranty doesn't extend to a second buyer since I purchased it used.
JM.
Jon
France
Tesla, Energica
In the US, the OEM warranty terms apply to all owners unless specifically stated otherwise, and that has limitations.
BTOR
Brad
2023 Bolt, 2025 R1S
Perhaps a silly question and obvious to others, but what does Rivian consider the "effective date"? I assume it is the delivery date i.e. when you take ownership? That would make the most sense. However, best not to assume (I'm sure you all know the saying......).
“The New Vehicle Limited Warranty starts on the day that your Rivian was originally delivered or put into service.”
https://rivian.com/support/article/when-does-the-warranty-period-start-on-my-rivian-vehicle
SwampNut
Carlos
Peoria AZ
2022 R1T Launch Edition
Geek
You can request this in the app or by email if you don't know your in-service date.
Hi Carlos,
My name is Nemanja, and I'm reaching out on behalf of the Rivian Customer Support Team—hope you're having a great day!
As requested, please find a detailed overview of the warranty coverage associated with your vehicle:
Coverage: 96 months / 175,000 miles
Start Date: September 16, 2022
End Date: September 16, 2030
Status: Active
Coverage: 60 months / 60,000 miles
End Date: September 16, 2027
Status: Active
Brake Lining Limited Warranty
Coverage: 12 months / 12,000 miles
End Date: May 28, 2024
Status: Expired
Tire Limited Warranty
Coverage: 12 months / 50,000 miles
Status: Expired
12V Battery Limited Warranty
Coverage: 36 months / 36,000 miles
End Date: September 16, 2025
Status: Active
Coverage: 96 months / Unlimited miles
Status: Active
Battery Pack Limited WarrantyBattery Pack Limited Warranty
Status: Active
Status: Active
Coverage: 96 months / 100,000 miles
Status: Active
To help keep your inbox organized, I’ll go ahead and close this case. Please note that future replies to
this thread won’t be monitored.
If you need any additional assistance, please submit a new request through our online form here. You can
also give us a call at 888-RIVIAN-1 or chat with us.
Thank you for being a part of the Rivian community!
Your fellow adventurer,
Nemanja
