DuoRivians
- Joined
- Dec 30, 2022
- Threads
- 193
- Messages
- 2,843
- Reaction score
- 6,646
- Location
- California
- Vehicles
- R1T, MY
- Thread starter
- #1
https://rivian.software/version-2023-02-0/
Version 2023.02.0
Released 01/24/2023 Type: BetaBuild: d434197a
Improved EPA – Estimated Range Numbers
Thanks to various incremental improvements over previous software updates, this update includes updated EPA-estimated range. The update also increases the depth of discharge, which increases the usable battery energy. You see higher available miles at the top of charge and efficiency update in the efficiency graph and trip computer.
NOTE: Reset the range history first for your vehicle to reflect the updated estimated range numbers.
To reset range history, on the center display, go to Vehicle > Energy > Range based on > Reset History.
Key Fob Software Update
The new key fob firmware improves connection reliability and latency for faster locking and unlocking. It also improves battery life performance compared to very early versions of the firmware. If your key fob has an update available, your vehicle will notify you on the center display. You can also go to Settings > Vehicle > Updates.
IMPORTANT: When updating your key fob software, we recommend that you have your phone set up as a key or have a spare key, such as a near-field communication (NFC) card as a backup.
New Door Ajar Notification
When proximity locking and unlocking is enabled, you will now be notified via the Rivian mobile app if the vehicle fails to lock due to a door or closure that is left open, and you’ve left the vicinity of the vehicle.
Additional Improvements
Reduced steering effort to maintain straight ahead driving on crowned roads.
Software containment for front trunk latch sensor issue resulting in reduced sleep and increased overnight range loss.
Addressed a rare case where Direct Current Fast Charger (DCFC) was slowed due to insufficient battery cooling.
Fixed an occasional issue where changes to suspension settings were unavailable due to cold ambient temperatures.
Improved compatibility with BC Hydro and Flo charging networks.
Range estimation fixes
Fixed a frequent issue where range estimation was incorrectly higher in Tow Mode (Thanks for the video, Zach!).
Fixed a rare issue where incorrect top of charge range was seen based on wheel configuration.
New Power Outlet Timer: In the Energy app you can now set a timer in increments of 1 hour up to 8 hours, for when your power outlets will turn off. Auto turn off after 24 hours is still available.
Gear Guard improvements
Reduced the number of extraneous videos by up to 30% by improving the accuracy of the Gear Guard video algorithms and handling stationary objects, such as a mailbox, traffic cone, sign board, fence, and adverse weather, such as rain and snow
Gear Guard video recordings will include footage recorded from all cameras before the triggering event was detected.
Remote cabin preconditioning and heated surfaces improvements
New Vented Seats remote command when used with the Rivian Mobile App 1.10 and later.
Addressed an issue where sending cabin preconditioning and heated surfaces remote commands from the mobile app were not successful in close proximity to the vehicle.
Improved consistency when sending multiple heated surface commands at the same time from the mobile app.
Fixed an occasional issue where the defrost command was not functional.
Window control improvements
Individual recalibration or reset of all windows can now be done from the driver side master switches. See R1 Owner Guide for recalibration or reset procedure.
Improved window close speed.
Improved window object detection and reaction.
Media improvements
Steering wheel buttons now handle seek differently for music and podcasts.
Music will move to next song
Podcasts will skip 15 seconds
Fixed the issue in Spotify where the artist’s name was hidden on albums and playlists.
Fixed an intermittent issue where song progress goes to 00:00 after coming back from another media source.
Fixed an intermittent issue where Spotify did not load the content on initial load.
Fixed an intermittent issue where incorrect radio state displayed when resumed to radio from a phone call.
Phone screen fixes
Fixed an intermittent issue where an incorrect phone number displayed on the flyout panel.
Fixed an intermittent issue where the selected contact card didn’t display the correct phone number (more frequent after FaceTime calls)
Fixed an issue where language switching did not work after infotainment reset.
Addressed certain cases where Highway Assist was unavailable due to errors related to Global Navigation Satellite System corrections.
Addressed an issue where Park Assist chimes were provided for select zones in the rear, while rear accessory mode was enabled.
Version 2023.02.0
Media improvements
Phone screen fixes
