johstacy
I probably already know the answer to this but this API is read only we can't send automation commands to it can we?
OverZealous
Louisville, Kentucky
Wonder if that means the wiring is still there for it.
Probably has the wiring for it just like the Frunk has the 12v wiring for the outlet that they no longer install...
Given how the integration is set up, they are mostly just pulling down any known pieces of data. There isn't a lot of sophistication on these sensors at this time, so they aren't showing whether there is or isn't a feature.
You'll also notice things like "Heated Seat 3rd Row Left" and "…Right", as well as "Liftgate", because these are available for R1S's.
The guys maintaining this plugin are amazing, and have done a ton of work trying to reverse engineer the API, mostly blindly. There's no docs and the app's commands are encrypted which makes it basically impossible to peek at while the message is on the wire.
johstacy
I agree really amazing work I was hoping HA would get a Rivian plugin..... I wonder if the charger attached to the account will eventually have data we can pull maybe then we can pivot the data from the charger and the miles driven to automate cost projections and stuff like that
aw113sgte
WI
22 R1t
I spent a few hours on this. Apparently there are different versions of home assistant, the one I got in docker didn't have addon support. Adding hacs I couldn't figure out as it seems to require ssh access but to the docker, not the NAS itself. At that point I said screw it, too many complicated steps for a solution that is likely to be broken next update.
Then I went on a trip, in 15 degrees, cold soaked battery, snow tires, 190 miles. Estimated I would have 94 miles and ended with 75. That's good enough for me.
jshaff
jason
MA
Cybersecurity
Yea, i probably wouldn't go through the effort of setting up HA just for this use. But i did get an APU key from Iterno and can confirm that everything works as expected.
Will certainly make me feel better about taking trips up north where non-tesla L3 charging is sparse.
Hmm, never used HA or node red, I do have a Synology Nas running at home, wonder if that would work.
Yes, HA will run on Synology, either as a VM or in a Docker container. I'm running HA in a VM on a Win 11 box. I would prefer to use a Pi but I have some weather station data logging software that only runs in Windows, so I just use it as the host for all my automation software. 🙄
I run a Universal Devices home controller. There's a Tesla Polyglot Node Server available, but nothing for Rivian yet. I've been kicking around the idea of writing a Rivian Noder Server for ISY. In my spare time, lol.
zefram47
R1T, C6 Corvette GS
Not sure what weather station you have, but you ought to look into WeeWX and see if there's either native support or if someone has developed a plugin for it. I've been using it since 2019 when Acurite stopped supporting their network link and used a raw SDR plugin to grab data over the air instead. I've since switched to a WeatherFlow Tempest unit and have been happy with it so I can continue sending data to various 3rd party sites like WeatherUnderground and CWOP.
I've got a Davis Vantage Pro 2. I'm using their Windows WeatherLink.exe to push data to WeatherLink and CWOP, and also using it to historically log data on the local drive for my farm. It's the local historical data logging that's missing from the plugins....
zefram47
R1T, C6 Corvette GS
Not to derail the thread too much, but WeeWX does keep a local database as well.
rivmok
MD
Audi RS3, Jeep Wrangler
You can set it up without ssh access, the docs for HACS are pretty poor. I was able to get everything installed and configured via the UI.
mindstormsguy
Seattle area
Some
Sorry for the delay. It has been a busy day or two. Here's the JSON for my Node-RED automation.
Code:
        "id": "0a240ace5f73b97b",
        "type": "tab",
        "label": "Rivian HA to ABRP",
        "disabled": false,
        "info": "",
        "env": []
        "id": "c454216dc2556369",
        "type": "debug",
        "z": "0a240ace5f73b97b",
        "name": "debug 1",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "targetType": "full",
        "statusVal": "",
        "statusType": "auto",
        "x": 1080,
        "y": 1200,
        "wires": []
        "id": "14022a8a7c8ddd12",
        "type": "api-current-state",
        "name": "",
        "server": "a32a31f29e50c3e6",
        "version": 3,
        "outputs": 2,
        "halt_if": "0",
        "halt_if_type": "num",
        "halt_if_compare": "is_not",
        "entity_id": "sensor.rivian_energy_storage_charger_adjusted_soc",
        "state_type": "num",
        "blockInputOverrides": false,
        "outputProperties": [
                "property": "soc",
                "propertyType": "msg",
                "value": "",
                "valueType": "entity"
        "for": "0",
        "forType": "num",
        "forUnits": "minutes",
        "override_topic": false,
        "state_location": "payload",
        "override_payload": "msg",
        "entity_location": "data",
        "override_data": "msg",
        "x": 300,
        "y": 220,
        "wires": [
                "a440d83de0c8e2af"
                "a440d83de0c8e2af"
        "id": "7a1610ae1d247444",
        "type": "inject",
        "name": "",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "payloadType": "date",
        "x": 100,
        "y": 40,
        "wires": [
                "4ead270d32eb384d"
        "id": "b05ee18031c7316a",
        "name": "",
        "version": 3,
        "outputs": 2,
        "halt_if": "0",
        "entity_id": "device_tracker.rivian_telematics_gnss_position",
                "property": "gnss_pos",
                "value": "",
        "for": "0",
        "forType": "num",
        "x": 280,
        "y": 320,
        "wires": [
                "90d82bfaaf202136"
                "90d82bfaaf202136"
        "id": "7a5419607ca5a690",
        "name": "",
        "version": 3,
        "outputs": 2,
        "halt_if": "on",
        "halt_if_type": "str",
        "halt_if_compare": "is",
        "entity_id": "binary_sensor.rivian_energy_storage_charger_vehicle_charger_state",
        "state_type": "str",
                "property": "charger_state",
                "value": "",
        "for": "0",
        "forType": "num",
        "x": 350,
        "y": 420,
        "wires": [
                "2b541098e215ebf0"
                "f351f1c74cba3687"
        "id": "2bbdf70f71bf9e1f",
        "name": "",
        "version": 3,
        "outputs": 2,
        "halt_if": "park",
        "entity_id": "sensor.rivian_dynamics_propulsion_status_prndl",
                "property": "pndrl",
                "value": "",
        "for": "0",
        "forType": "num",
        "x": 370,
        "y": 800,
        "wires": [
                "b167da69e56601b9"
                "528037b5d00342c8"
        "id": "2e84984fea4471cd",
        "name": "",
        "version": 3,
        "outputs": 2,
        "halt_if": "0",
        "entity_id": "sensor.rivian_dynamics_odometer_value",
                "property": "odometer",
                "value": "",
        "for": "0",
        "forType": "num",
        "x": 340,
        "y": 900,
        "wires": [
                "75ef08d69eb660a2"
                "75ef08d69eb660a2"
        "id": "e4c6f1202963fef4",
        "name": "",
        "version": 3,
        "outputs": 2,
        "halt_if": "0",
        "entity_id": "sensor.rivian_energy_storage_vehicle_energy_vehicle_range",
                "property": "range",
                "value": "",
        "for": "0",
        "forType": "num",
        "x": 410,
        "y": 1000,
        "wires": [
                "0c3d67e44a777549"
                "0c3d67e44a777549"
        "id": "a440d83de0c8e2af",
        "type": "change",
        "name": "",
        "rules": [
                "t": "set",
                "p": "abrp.soc",
                "pt": "msg",
                "to": "soc.state",
                "tot": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 750,
        "y": 220,
        "wires": [
                "b05ee18031c7316a"
        "id": "90d82bfaaf202136",
        "type": "change",
        "name": "",
        "rules": [
                "t": "set",
                "p": "abrp.lat",
                "pt": "msg",
                "to": "gnss_pos.attributes.latitude",
                "tot": "msg"
                "t": "set",
                "p": "abrp.lon",
                "pt": "msg",
                "to": "gnss_pos.attributes.longitude",
                "tot": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 740,
        "y": 320,
        "wires": [
                "7a5419607ca5a690"
        "id": "2b541098e215ebf0",
        "type": "change",
        "name": "abrp.is_charging true",
        "rules": [
                "t": "set",
                "p": "abrp.is_charging",
                "pt": "msg",
                "to": "true",
                "tot": "bool"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 800,
        "y": 400,
        "wires": [
                "cfe681d3b9c224e6"
        "id": "f351f1c74cba3687",
        "type": "change",
        "name": "abrp.is_charging flase",
        "rules": [
                "t": "set",
                "pt": "msg",
                "to": "false",
                "tot": "bool"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 180,
        "y": 700,
        "wires": [
                "c4716e5dedb1f833"
        "id": "b167da69e56601b9",
        "type": "change",
        "name": "",
        "rules": [
                "t": "set",
                "p": "abrp.is_parked",
                "pt": "msg",
                "to": "true",
                "tot": "bool"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 910,
        "y": 780,
        "wires": [
                "2e84984fea4471cd"
        "id": "528037b5d00342c8",
        "type": "change",
        "name": "",
        "rules": [
                "t": "set",
                "pt": "msg",
                "to": "false",
                "tot": "bool"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 910,
        "y": 820,
        "wires": [
                "2e84984fea4471cd"
        "id": "75ef08d69eb660a2",
        "type": "function",
        "name": "mi to km (odo)",
        "func": "msg.abrp.odometer = 1.60934 * msg.odometer.state;\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 880,
        "y": 900,
        "wires": [
                "e4c6f1202963fef4"
        "id": "0c3d67e44a777549",
        "type": "function",
        "name": "mi to km (range)",
        "func": "msg.abrp.est_battery_range = 1.60934 * msg.range.state;\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 880,
        "y": 1000,
        "wires": [
                "e796a7b0516dfeee"
        "id": "abd7d01f161fbb41",
        "type": "function",
        "name": "Set time",
        "func": "msg.abrp.utc = parseInt(msg.payload / 1000);\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 700,
        "y": 100,
        "wires": [
                "b1d22d718b934e36"
        "id": "e796a7b0516dfeee",
        "type": "json",
        "name": "build json",
        "property": "abrp",
        "action": "str",
        "pretty": false,
        "x": 180,
        "y": 1120,
        "wires": [
                "59e29f544e2021e1"
        "id": "5530d4dedffbb2c1",
        "type": "function",
        "name": "build request",
        "func": "msg.method = \"get\";\nmsg.url = \"https://api.iternio.com/1/tlm/send?api_key=\" + msg.api_key + \"&token=\" + msg.token + \"&tlm=\" + msg.abrp;\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 650,
        "y": 1120,
        "wires": [
                "d451af60021e9b68"
        "id": "d451af60021e9b68",
        "type": "http request",
        "name": "",
        "method": "use",
        "ret": "txt",
        "paytoqs": "ignore",
        "url": "",
        "tls": "",
        "persist": false,
        "proxy": "",
        "insecureHTTPParser": false,
        "authType": "",
        "senderr": false,
        "headers": [],
        "x": 870,
        "y": 1120,
        "wires": [
                "c454216dc2556369"
        "id": "c3d9961fc33c39af",
        "type": "server-state-changed",
        "name": "",
        "version": 4,
        "exposeToHomeAssistant": false,
        "haConfig": [
                "property": "name",
                "value": ""
                "property": "icon",
                "value": ""
        "entityidfilter": "rivian",
        "entityidfiltertype": "substring",
        "outputinitially": true,
        "haltifstate": "",
        "outputs": 1,
        "output_only_on_state_change": false,
        "for": "0",
        "forType": "num",
        "ignorePrevStateNull": false,
        "ignorePrevStateUnknown": false,
        "ignorePrevStateUnavailable": false,
        "ignoreCurrentStateUnknown": false,
        "ignoreCurrentStateUnavailable": false,
                "property": "payload",
                "value": "",
                "valueType": "date"
                "property": "data",
                "value": "",
                "valueType": "eventData"
                "property": "topic",
                "value": "",
                "valueType": "triggerId"
        "x": 120,
        "y": 100,
        "wires": [
                "e03464546451ac49"
        "id": "e03464546451ac49",
        "type": "delay",
        "name": "",
        "pauseType": "delay",
        "timeout": "1",
        "timeoutUnits": "seconds",
        "rate": "1",
        "nbRateUnits": "1",
        "rateUnits": "second",
        "randomFirst": "1",
        "randomLast": "5",
        "randomUnits": "seconds",
        "drop": false,
        "allowrate": false,
        "outputs": 1,
        "x": 360,
        "y": 100,
        "wires": [
                "4ead270d32eb384d"
        "id": "1d65b486bac7ea2f",
        "type": "comment",
        "name": "Wait for all data before polling ",
        "info": "Wait a second for all the data to be parsed by HA",
        "x": 380,
        "y": 40,
        "wires": []
        "id": "63ed731a41f823e9",
        "type": "comment",
        "name": "Rate limit",
        "info": "Per https://documenter.getpostman.com/view/7396339/SWTK5a8w, the desired update rate is once ever 5 second, but no greater.",
        "x": 840,
        "y": 40,
        "wires": []
        "id": "4ead270d32eb384d",
        "type": "change",
        "name": "",
        "rules": [
                "t": "set",
                "p": "abrp.utc",
                "pt": "msg",
                "to": "0",
                "tot": "num"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 530,
        "y": 100,
        "wires": [
                "abd7d01f161fbb41"
        "id": "59e29f544e2021e1",
        "type": "credentials",
        "name": "token",
        "props": [
                "value": "token",
                "type": "msg"
        "x": 330,
        "y": 1120,
        "wires": [
                "16454682fa7ca495"
        "id": "16454682fa7ca495",
        "name": "api_key",
        "props": [
                "value": "api_key",
                "type": "msg"
        "x": 480,
        "y": 1120,
        "wires": [
                "5530d4dedffbb2c1"
        "id": "b1d22d718b934e36",
        "type": "function",
        "name": "Rate Limiter",
        "func": "var interval = (5000); // minimum interval between messages (ms)\ncontext.lastTime = context.lastTime || 0;\n\nvar now = Date.now();\n\nif (now-context.lastTime > interval) {\n  context.lastTime = now;\n  return msg;\n} else {\n  return null;\n}",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 870,
        "y": 100,
        "wires": [
                "14022a8a7c8ddd12",
                "7f5bd5c5cdd0048e"
        "id": "cfe681d3b9c224e6",
        "name": "",
        "version": 3,
        "outputs": 2,
        "halt_if": "on",
        "entity_id": "binary_sensor.rivian_energy_storage_charger_status_vehicle_charger_status",
                "property": "charger_status",
                "value": "",
        "for": "0",
        "forType": "num",
        "x": 700,
        "y": 620,
        "wires": [
                "f2325791a7154198",
                "c28447f3c67b3e41"
                "c28447f3c67b3e41"
        "id": "c4716e5dedb1f833",
        "type": "change",
        "name": "abrp.is_dcfc flase",
        "rules": [
                "t": "set",
                "p": "abrp.is_dcfc",
                "pt": "msg",
                "to": "false",
                "tot": "bool"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 410,
        "y": 700,
        "wires": [
                "2bbdf70f71bf9e1f"
        "id": "7f5bd5c5cdd0048e",
        "type": "debug",
        "name": "debug 2",
        "active": false,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "statusVal": "",
        "x": 1140,
        "y": 60,
        "wires": []
        "id": "f2325791a7154198",
        "type": "debug",
        "name": "debug 3",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "statusVal": "",
        "x": 1140,
        "y": 500,
        "wires": []
        "id": "c28447f3c67b3e41",
        "type": "function",
        "name": "infer DCFC",
        "func": "msg.abrp.is_dcfc = (msg.charger_status.attributes.value != \"chrgr_sts_connected_charging\");\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 1150,
        "y": 620,
        "wires": [
                "2bbdf70f71bf9e1f"
        "id": "a32a31f29e50c3e6",
        "type": "server",
        "name": "Home Assistant",
        "version": 5,
        "addon": false,
        "rejectUnauthorizedCerts": true,
        "ha_boolean": "y|yes|true|on|home|open",
        "connectionDelay": true,
        "cacheJson": true,
        "heartbeat": false,
        "heartbeatInterval": "30",
        "areaSelector": "friendlyName",
        "deviceSelector": "friendlyName",
        "entitySelector": "friendlyName",
        "statusSeparator": ": ",
        "statusYear": "hidden",
        "statusMonth": "short",
        "statusDay": "numeric",
        "statusHourCycle": "default",
        "statusTimeFormat": "h:m",
        "enableGlobalContextStore": false
Yellow Buddy
Behind You
Smart Ass
Just one clarification, the flow goes like this:
  • Truck sends data Rivian Servers
  • HA plugin to grab the data from Rivian (so that I don't have to maintain my own code to talk to the ever-changing Rivian API)
  • Node Red plugin to pull sensor data from HA (so that I don't have to learn how to write my own direct HA plugin)
  • Node Red HTTP GET call to publish the data to ABRP
All of that is just running on a server at my house, so it magically chugs away without any interaction by me. At that point, I can open ABRP anywhere on any device and it will have live data from my truck.
Eventually, if Rivian releases the rumored web browser, this could even work with a UI right on the main screen. It would just be a really indirect path the information being displayed 😅. But given how they said the browser is delayed while they figure out the security model to isolate the browser so it's not an attack vector, I doubt anything more direct would be possible.
I know you’re trying to help dumb it down, but after 2 pages here’s what I gathered.
To enable ABRP on my truck, I first need to…call you.
I will then head to my local post office and mail you my flip phone. You will mail it back to me where it will then magically work. I’ll be more than happy to pay you for it, is a money order ok?
Yellow Buddy
Behind You
Smart Ass
Code:
        "type": "tab",
        "disabled": false,
        "info": "",
        "env": []
        "type": "debug",
        "name": "debug 1",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "statusVal": "",
        "x": 1080,
        "y": 1200,
        "wires": []
        "name": "",
        "version": 3,
        "outputs": 2,
        "halt_if": "0",
                "property": "soc",
                "value": "",
        "for": "0",
        "forType": "num",
        "x": 300,
        "y": 220,
        "wires": [
                "a440d83de0c8e2af"
                "a440d83de0c8e2af"
        "type": "inject",
        "name": "",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "x": 100,
        "y": 40,
        "wires": [
                "4ead270d32eb384d"
        "name": "",
        "version": 3,
        "outputs": 2,
        "halt_if": "0",
                "value": "",
        "for": "0",
        "forType": "num",
        "x": 280,
        "y": 320,
        "wires": [
                "90d82bfaaf202136"
                "90d82bfaaf202136"
        "name": "",
        "version": 3,
        "outputs": 2,
        "halt_if": "on",
                "value": "",
        "for": "0",
        "forType": "num",
        "x": 350,
        "y": 420,
        "wires": [
                "2b541098e215ebf0"
                "f351f1c74cba3687"
        "name": "",
        "version": 3,
        "outputs": 2,
        "halt_if": "park",
                "value": "",
        "for": "0",
        "forType": "num",
        "x": 370,
        "y": 800,
        "wires": [
                "b167da69e56601b9"
                "528037b5d00342c8"
        "name": "",
        "version": 3,
        "outputs": 2,
        "halt_if": "0",
                "value": "",
        "for": "0",
        "forType": "num",
        "x": 340,
        "y": 900,
        "wires": [
                "75ef08d69eb660a2"
                "75ef08d69eb660a2"
        "name": "",
        "version": 3,
        "outputs": 2,
        "halt_if": "0",
                "value": "",
        "for": "0",
        "forType": "num",
        "x": 410,
        "y": 1000,
        "wires": [
                "0c3d67e44a777549"
                "0c3d67e44a777549"
        "type": "change",
        "name": "",
        "rules": [
                "t": "set",
                "p": "abrp.soc",
                "pt": "msg",
                "to": "soc.state",
                "tot": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 750,
        "y": 220,
        "wires": [
                "b05ee18031c7316a"
        "type": "change",
        "name": "",
        "rules": [
                "t": "set",
                "p": "abrp.lat",
                "pt": "msg",
                "tot": "msg"
                "t": "set",
                "p": "abrp.lon",
                "pt": "msg",
                "tot": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 740,
        "y": 320,
        "wires": [
                "7a5419607ca5a690"
        "type": "change",
        "rules": [
                "t": "set",
                "pt": "msg",
                "to": "true",
                "tot": "bool"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 800,
        "y": 400,
        "wires": [
                "cfe681d3b9c224e6"
        "type": "change",
        "rules": [
                "t": "set",
                "pt": "msg",
                "to": "false",
                "tot": "bool"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 180,
        "y": 700,
        "wires": [
                "c4716e5dedb1f833"
        "type": "change",
        "name": "",
        "rules": [
                "t": "set",
                "pt": "msg",
                "to": "true",
                "tot": "bool"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 910,
        "y": 780,
        "wires": [
                "2e84984fea4471cd"
        "type": "change",
        "name": "",
        "rules": [
                "t": "set",
                "pt": "msg",
                "to": "false",
                "tot": "bool"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 910,
        "y": 820,
        "wires": [
                "2e84984fea4471cd"
        "type": "function",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 880,
        "y": 900,
        "wires": [
                "e4c6f1202963fef4"
        "type": "function",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 880,
        "y": 1000,
        "wires": [
                "e796a7b0516dfeee"
        "type": "function",
        "name": "Set time",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 700,
        "y": 100,
        "wires": [
                "b1d22d718b934e36"
        "type": "json",
        "property": "abrp",
        "action": "str",
        "pretty": false,
        "x": 180,
        "y": 1120,
        "wires": [
                "59e29f544e2021e1"
        "type": "function",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 650,
        "y": 1120,
        "wires": [
                "d451af60021e9b68"
        "name": "",
        "method": "use",
        "ret": "txt",
        "url": "",
        "tls": "",
        "persist": false,
        "proxy": "",
        "authType": "",
        "senderr": false,
        "headers": [],
        "x": 870,
        "y": 1120,
        "wires": [
                "c454216dc2556369"
        "name": "",
        "version": 4,
        "haConfig": [
                "property": "name",
                "value": ""
                "property": "icon",
                "value": ""
        "haltifstate": "",
        "outputs": 1,
        "for": "0",
        "forType": "num",
                "value": "",
                "valueType": "date"
                "property": "data",
                "value": "",
                "value": "",
        "x": 120,
        "y": 100,
        "wires": [
                "e03464546451ac49"
        "type": "delay",
        "name": "",
        "timeout": "1",
        "rate": "1",
        "nbRateUnits": "1",
        "randomFirst": "1",
        "randomLast": "5",
        "drop": false,
        "allowrate": false,
        "outputs": 1,
        "x": 360,
        "y": 100,
        "wires": [
                "4ead270d32eb384d"
        "type": "comment",
        "x": 380,
        "y": 40,
        "wires": []
        "type": "comment",
        "x": 840,
        "y": 40,
        "wires": []
        "type": "change",
        "name": "",
        "rules": [
                "t": "set",
                "p": "abrp.utc",
                "pt": "msg",
                "to": "0",
                "tot": "num"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 530,
        "y": 100,
        "wires": [
                "abd7d01f161fbb41"
        "name": "token",
        "props": [
                "value": "token",
                "type": "msg"
        "x": 330,
        "y": 1120,
        "wires": [
                "16454682fa7ca495"
        "name": "api_key",
        "props": [
                "value": "api_key",
                "type": "msg"
        "x": 480,
        "y": 1120,
        "wires": [
                "5530d4dedffbb2c1"
        "type": "function",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 870,
        "y": 100,
        "wires": [
                "14022a8a7c8ddd12",
                "7f5bd5c5cdd0048e"
        "name": "",
        "version": 3,
        "outputs": 2,
        "halt_if": "on",
                "value": "",
        "for": "0",
        "forType": "num",
        "x": 700,
        "y": 620,
        "wires": [
                "f2325791a7154198",
                "c28447f3c67b3e41"
                "c28447f3c67b3e41"
        "type": "change",
        "rules": [
                "t": "set",
                "pt": "msg",
                "to": "false",
                "tot": "bool"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 410,
        "y": 700,
        "wires": [
                "2bbdf70f71bf9e1f"
        "type": "debug",
        "name": "debug 2",
        "active": false,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "statusVal": "",
        "x": 1140,
        "y": 60,
        "wires": []
        "type": "debug",
        "name": "debug 3",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "statusVal": "",
        "x": 1140,
        "y": 500,
        "wires": []
        "type": "function",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 1150,
        "y": 620,
        "wires": [
                "2bbdf70f71bf9e1f"
        "type": "server",
        "version": 5,
        "addon": false,
        "cacheJson": true,
        "heartbeat": false,
So is this feeding back to ABRP to improve their data? Or is it just for you to consume right now?
