R2 Range Estimates
SnowFlyer
2022 R1S Quad, Large Bat., 20” Wheels
My R2 Range Estimates
TLDR: 218 to 311 mi depending on configuration.
Standard Battery, Dual Motor:
218 mi
Standard Bat, Single Motor:
245 mi
Large Bat, Dual Motor:
276 mi
Large Bat, Single Motor:
311 mi
Estimates are Based on the following data from A Better Route Planner. Since ABRP is Owned By Rivian I expect these numbers to be very close:
Available Battery Capacity (from ABRP):
Standard: 75 kWh.
Large: 95 kWh
Efficiency at 65 mph (from ABRP):
Single Motor Efficiency: 3.27 miles/kWh
Dual Motor Motor Efficiency: 2.91 mi/kWh.
Considering that my Gen 1 Large Battery Quad R1S typically makes about the EPA range at 65 mph I think my estimates should be close.
I do wish these ranges were a bit longer (10% - 20% more), however I suspect most people will be happy daily driving any configuration and road tripping the large battery versions assuming charging speeds are decent (20-80% in 15 ish minutes).
I'm curious what other members think about the accuracy of these estimates. Also how fast do you expect the large to charge (20-80%)?
VandalSibs
Andrew
Eastern Washington State
www.sibulskymusic.com
R1T Dual Motor Large Pack
There's an entire other thread on this very subject that you could look into. Also, the battery capacity numbers from ABRP are complete guesses on their part. They have no more knowledge on that front that your average member of the public.
carsly
Princeton, NJ
LR Defender, Tesla Model S
VandalSibs
Andrew
DuoRivian
Rivian R1T and an R1S
These ranges are incorrect because EPA is not based on 65mph. No-one just does highway driving all the time.
mkg3
R1S, Model 3, Outback, Artura
218 mi
245 mi
276 mi
311 mi
These numbers would be fine in 2022, not in 2026. If R2 only delivered these ranges, it would be very inadequate in the segment it will compete in.
MClayton
Jeff
NH
Ram 1500, Toyota Rav4
Agreed. With those numbers we would buy something else for sure.
carsly
Princeton, NJ
You are technically correct, but the ABRP team works independently of Rivan itself. They have stated this in the past. From the other thread talking about the potential pack sizes in R2:
https://www.rivianforums.com/forum/...ft-is-allegedly-february-10.55741/post-946524
As someone who's spent decades doing M&A work, "independently" is something they may want people on the outside to think about as a marketing point. But in reality, no one acquires something to leave it alone entirely - makes for a sub-optimal investment case as all you end up doing is adding expense and overhead. That never maths, especially not for a public company.
Maybe ABRP left in some placeholders for pack sizes, but they didn't accidentally publish that a week or two before the embargo came off. It's the same company, someone in Rivian corporate knew about it and greenlit it.
The only way ABRP operates independently (no quotes) is if a friendly neighborhood PE firm does a carve out. But even then it's likely Rivian would continue to hold some equity and a board seat until it's sold again in a few years to another PE firm at which time Rivian would likely have an opportunity to liquidate most, or all, of its outstanding interest.
ABRP is in no way independent today. It's Rivian. Plain and simple. Rivian employees with Rivian benefits and Rivian stock options.
PS if you believe ABRP is independent, then the marketing ploy worked on you. Nothing wrong with that, but know it's marketing fluff and nothing else.
SnowFlyer
SnowFlyer
In my first post I stated that my Gen 1 R1S Quad "typically makes about the EPA range at 65 mph so I think my estimates should be close."
I hope my estimates are low, because as others have stated the R2's success is likely a make or break moment for Rivian and I believe that it probably needs 10-20% more range to be competitive.
VandalSibs
Andrew
You can be owned by a company, be considered an employee of that company, and still not know what the other parts are doing or be able to information. Happens all the time, in multiple industries. Hell, it happens in places that are the exact same company too!
DuoRivian
Very funky math given the R2 is more aerodynamic and weighs less. Just wait until tomorrow instead of pulling numbers out of thin air that are widely wrong.
