NEW - RIVIPARTS Left Side Phone Mount
eaa56
Prescott, AZ
Jeep Wrangler, ecoDiesel, Audi e-tron
Just what I've been waiting for. Hope to see it on sale on your site soon.
andrew
Salt Lake City
Yes. Launch plan is similar to the PRO. It should follow the 17MM by a few weeks. I generally do this so I can estimate volume as the 1" model is lower in that regard (3:1 or 4:1) and a bit more expensive to make.
I was thinking about this, and I wonder if it would be possible to leave the ball off and just have a hole for the bolt to pass through? Then people could add whichever size ball mount they want/need by getting a through hole ball. Even easier if, instead of using an M5 nut, it were to have a nut for 1/4"-20 since there are a plethora of balls with a 1/4"-20 bolt sticking out of them. Just something that might make it easier for people to adopt and you not be required to develop/build a separate mount for every size of ball that people might want.
RWerksman
RWerksman
Pittsburgh
Jeep & R1T
I've looked into this multiple times and it never works. The cost difference between getting one produced with a hole and a ball on it is insubstantial. It's more offset when you factor in the additional hardware that will be needed to keep it in place. Pricing advances for purchasers would just not be there either.
It's one of those instances where design and common sense doesn't jive with production constraints.
ForestGump
Southen Cal
Tesla Model S, Y, Rivian R1T
Will you be producing a left side 20mm ball mount for RAM users? Thanks
RWerksman
RWerksman
Pittsburgh
Jeep & R1T
RAM uses a 1" mount. That's what you're asking for, right? 20MM is for Offroam x Peak Designs.
Depending on how these do, both in sales and issues - yes, I will. It's a bit off though.
TheHedgehog116
Manny
Oxnard
'12 Charger
Anyone have an issue where you plug in something to the OBDII port and it's not receiving power? I tried turning on outlets and driving my truck around and the device I plugged in isn't receiving power.
RWerksman
RWerksman
Pittsburgh
Jeep & R1T
Not here. The Scosche OBD II to USB Q3 adapter lit up red immediately after plugging it in.
RWerksman
RWerksman
Pittsburgh
Jeep & R1T
Hello my dudes!
These arrived late yesterday and most of the backorders have been completed and sent today. I'm expecting to get through the remainder of the backorders tomorrow for shipping on Monday.
Additionally, installation instructions for these will be posted shortly. A link to the instructions page was included with all of the outbound shipments.
The response to these has exceeded my expectations. I hope you all love them as much as I loved the process of creating them! ❤
idontknow544
Hi thanks for making this! I'm a little new to 3d printing, do you have any suggestions for getting the ball piece printed? I'm having trouble printing that piece, it doesn't seem to want to stick to the plate. Thanks again!
jebinc
Received and installed mine today! Shipping was quick, thank you!
RWerksman
RWerksman
Pittsburgh
Jeep & R1T
Hey there, apologies for not seeing the post. You may want to look into a brim (preferred) or a raft (alternate) to get this to print correctly for you. You may also want to try something to promote bed adhesion to get it to stick.
Does that help?
idontknow544
Thanks for the response! I figured out that increasing the temperature solved the sticking issue. Although now that I have it printed out, I'm struggle getting the small back piece to fit inside the vent. Any suggestions?
RWerksman
RWerksman
Pittsburgh
Jeep & R1T
There are install instructions on the website with a bit of info. Go SLOW though and don't force it. It's tricky the first time but it's easier once you get the hang of it.
agame32
GTI, Y
I had your right side mount, but this left side mount is perfect. Brilliant, simple design for how it attaches to the truck. Good job by you, @RWerksman! 🙌🏼
