NineElectrics
The Edmunds test is useless for range. It’s OK for efficiency. Almost everyone wants to know “road trip” range, not “how long can I Uber in the city” range. Edmunds gives you more of the latter. Even EPA won’t give you road trip range: they mix in city results, which on EVs increases the final number. On ICE cars blending in city range decreases EPA, which is why you’re more likely to meet your ICE EPA range on a road trip.
Rivians are boxy cars. 30 mph vs 70 makes a huge difference. As does temperature. Rivian needs to add a heat pump, stat.
Throwdown
R1t launch edition#2650
Technician
80 F is probably about optimal temp for the Rivian. Batteries are the most efficient when they are warm and A/C is still pretty efficient. Air density is lower so less wind resistance. Hotter than that and they probably need to expend energy to keep the battery cooler too.
Lithium Batts want to be exactly 83 F
Davis
San Diego
Business Development
I have 21” highways on my R1T, made a couple of dozen trips between LA & SD always in conserve, I drive between 70&80 and have never gotten over 285 actual on the trip meter, even considering all of the latest updates. 100%,full charge shows me starting at 351, never drained it below 5%! 330 is a stretch..🤔
Where did you get the info that the test was entirely in conserve mode? I did not see that in the article?
Edmunds states they always test in the most economical mode.
kanundrum
Washington, DC
Giulia QV, R1S (S00N)
Here is the differentials, no big deal IMHO.
Beginning with 2023 R1S models built after January 2023, Rivian implemented countermeasures to the driver-side floor pan to improve occupant safety in front crashes.
Rivian R1T R1S Edmunds: R1S range tested on 20” AT tires 1683130423309
22vs23
Rivian R1T R1S Edmunds: R1S range tested on 20” AT tires 1683130438654
Southern R1S
2023 R1S (LE/GW/OC/20"AT), Lexus GX 460 Luxury
Builder
I guess us 2022 R1S owners can just go die then
Some would call that the ultimate "early adopter tax" -- or just the price to pay for Meridian Audio, Wood headrest trim, and 12v outlets.
Only (partially) kidding, of course.
kanundrum
Washington, DC
You are tough kanundrum, I am betting you can survive a right lower leg injury.
Time to make a CarbonFiber Weathermat Monocoque !
camaroz1985
Carlisle, PA
R1T, ID.4
I guess us 2022 R1S owners can just go die then, us discord folks talked about it:
22vs23
Not die, just have slightly mangled feet. Wonder why it is different from R1T, everything should be the same in this area. I guess the shorter wheelbase and similar center of gravity height could see more weight transfer in the impact?
Biturbowned
MD
‘20 Model Y, ‘22 R1T
So you’re suggesting that Rivian shouldn’t fix a safety-related issue that’s within their ability to fix?
kanundrum
Washington, DC
I was just joking lol. But I don't think it's a fix unless they came up with something to adjust driver's right front intrusion/absorbtion post redesign that can be a add on vs a new component.
Older cars crash worse than newer models, you don't see companies adjusting accordingly. Standard operating procedure, BAU.
