macb00kemdanno
Brandon
Garner, NC
2024 Tesla Model 3 Long Range Dual Motor, 2023 Tesla Model Y Long Range
Both of our EVs have a heat pump, so I don't have any experience with resistive heat in EVs. What's the efficiency hit with the R1 platform when using the current method of heating?
dleepnw
Rivian, Toyota, Lexus
good! will be a big improvement to efficiency
Reactions: Rad
zefram47
Rivian R1T, Alfa Romeo 4C
The difference likely won't be as big as people want to see. My MINI Cooper SE had a heat pump and below probably 32F I'd notice a pretty big hit to efficiency. That said, that vehicle didn't have a battery warmer so some of its cold weather inefficiency was likely due to that issue. In warm weather I'd see around 4-4.2 mi/kWh, but below 32F it dropped to more like 3.5 mi/kWh and closer to 10F it was more like 3 mi/kWh. Can't say all of that is due to heating the cabin, but I saw a 25-30% impact from temperature alone with no change in driving style/location.
KootenayEV
Andrew
Nelson, BC
R1T, Tesla Model 3
Environmental Engineer
On my 2014 Leaf the heat pump made a tangible difference - on my R1T I don’t care what provides the heat so long as it is reliable and isn’t ridiculously expensive to fix.
not_a_car_guy
Massachusetts
R1T Perf Dual Motor
I have to admit I like how quickly the non-heat-pump heater starts working. It's quite luxurious coming from an ICE where it would take minutes before anything was warmer than the air already in the car.
