EVman
- Thread starter
- #1
Met my Silverado to swap trailers on the road today. When I connect the trailer Rivian the trailer lights it did not work. Switched it back to the Silverado and it works. Even checked the 7way to 4 connector on the Silverado. The lights always work but on the Rivian it doesn't. So I call support and I get the book readers. Sir you need a 7 pin to 4 pin adapter to connect your trailer lights to your Rivian. I have that it is already connected but it does not work. 2 Hrs. and three support staff I could still not get through to them. Those very simple words, "Sir, I don't know" could not be spoken neither could they find the inclination to listen to me. One went as far to tell me that gas vehicles is very different that the Ev's you cannot compare them. Idiot's.
So the answer is that Rivian will not work with a trailer with LED lights we found that out the hard way. Tail lights work because there are two side markets and two tail lights. They are nice and bright because there is enough resistance for the Rivian to sense the circuit. I think. However the brake lights two lights are not enough resistance to sense the circuit, same for the blinker only one light. Two check this I added a resistor to my test lamp and yes I get a nice bright test light. Remove the resistor and the test light hardly lights up. My test light is also LED.
The moral of the story is Rivian has a build problem with trailer lights and since it is illegal to sell incandescent lights it has a problem with all new trailers. I thought I could just add a resistor inline on my trailer but then it would not work on my other trucks. What a pain in the butt Rivian is.
