Aroohoo
- Thread starter
- #1
Had a August 2022 build R1T GW/BW/21”, just traded it back to Rivian for a July 2023 build R1S LS/BW/20”.
Initial thoughts coming from my T.
The obvious differences and ones that have been mentioned elsewhere:
- Truck vs SUV (I’m already missing the gear tunnel and a bed that I can throw dirty stuff in)
- Missing 12V plugs in the frunk and under the dash (this one I was actually using)
- No wood trim in the back of the headrests
- “Rivian” sound system. Although I can’t comment on the audio quality, I have noticed that stuff I listed to in the T that I had to set the volume to 14 to hear, I’m setting to 6.
- Lower wind noise.
- I had the triangle wind noise issue on the T that started to kick in at 30mph. On the S, I can make out some noise at >60mph if I move my ear close to the window.
- My T also had wind noise from the roof at >50mph. The S has much less. I still plan on trying to seal some of the gaps at the windshield and at the panoramic sunroof
- Frunk Heat
- It is extremely toasty. At only being 70-75 deg the past few days, all of the sides of the funk are really warm. I didn’t even have this on the T when it was 85+ with the AC having been on for a while. Side effect of having to cool more interior volume?
- Build quality is improved, but...
- No panel gap issues
- I did notice a dent in the roof trim (probably happened while being shipped) and one of the door handles isn’t mounted correctly (when closed the pivoting side hits the inside of the handle cut out by a good 3mm or so. Looks like the handle assembly wasn’t mounted correctly and/or the mounting holes for the handle assembly are off.
- Compressor Noise
- Others have stated that they can hear the compressor in the S, I haven’t noticed it.
- Ride Quality
- Some people have mentioned pourposing in the S relative to the T, but that isn’t something that I have noticed. There is a difference in ride quality, but this is likely due to 20s vs 21s
- Proximity unlocking is much, much better. Small sample size, but the effect is substantial enough for me to think to myself, this is SO much better.
- At least on mine, I still have a 12VDC Battery upfront and not the rumored capacitor. There was talk that the capacitor would be introduced in July.
