Time spent charging shouldn't be ignored as a factor. Level 2 is actually the sweet spot for most chemistries.I would say no. In fact it's probably more gentle since fast charging batteries degrade them faster, even if that is minimal.
You can do that if the outlet is a NEMA 5-20R and the adapter on the portable charging interface is a 5-20P but they are more probably 5-15 which limit to 12A. You can buy a Tesla UMC and a 5-20P adapter which, with a TeslaTap or similar adapter would allow you to charge your R1T from a 20A 125V outlet. The Tesla UMC is currently listed as "out of stock". Rivian may eventually make its own 5-20P adapter.If itās a dedicated 20A outlet, then set the truck max to 16A and forget about it. Just let it go all day.
Max from L1 is 120V @ 16A. Max from L2 is 240V @ 48A so L3 is 2*3 = 6 times faster. I don't think that's minimal. I think it appreciable but as "slightly" and "appreciable" are largely subjective words you can call it what you will.L2 is slightly better but the difference is minimal.
What is being balanced here? What does the BMS have to do with it?Mainly for balancing/BMs reasons but as.long as you hit it occasionally with a l2, I wouldn't worry at all about l1 charging daily.
yeah, I think the plan to charge at work via 110 is only going to work if OP works 1-week shiftsMy experience with charging an R1T with 110v is that it doesnāt really do anything. Best outcome is basically keeping the battery from discharging. Any actual charge increase is wishful thinkingā¦ your mileage may vary.
You're dreaming on 90% efficiency. There's probably 30% wasted to just keeping charging electrics and computers powered on. The power conversion factor might be 90% though...L1 charging on a 15A circuit means only 1.144 kW going to the charger. With 90% efficiency charging 24 hr delivers 10 kWh to the battery. Some drivers are reporting (before an OTA update) as much as 10 kWh/da phantom drain. If you can charge for only 8 hrs that doesn't leave much for the battery. With the OTA update phantom drain reports are much more reasonable at a coupe of kWh/da. With 2 kWh/da phantom drain the battery would get 8 kWh but that's only good for 16 miles which is much better but nevertheless few will be able to rely on L1 alone.
My response was in response to the benefits of L2 charging over L1 from a battery health perspective being present, but minimal. Someone previous that I was replying to had said l1 might even be healthier on the battery, which is not the case. As a rate of charge, of course L2 is a lot better.Max from L1 is 120V @ 16A. Max from L2 is 240V @ 48A so L3 is 2*3 = 6 times faster. I don't think that's minimal. I think it appreciable but as "slightly" and "appreciable" are largely subjective words you can call it what you will.
He can charge exclusively with L1 if he wants to (many people do) so long as he gets in enough hours for the charge he needs e.g. he can get as much free from his employer as he can in a workday and get the rest at home (as long as he gets enough from his employer to be able to get home).
