Max
That is definitely a concern for me. Maybe that is the reason for OC delays; if they are changing material or supplier to address that issue. My wife is pushing for OC. I saw Black (charcoal gray) up close and thought it was very classy and probably blend nicely with El Cap but still have OC in my config. I may be the only one that don’t want my R1 in 22, hoping they get a bit more reliable by 23 with less parasitic power loss. May be by then a few OCs are out there and someone can tell us if it is the good stuff or not. I hear Tesla’s white holds up well.I forget which member on this forum stated they saw the inside of an OC test Mule many months ago during testing, and the material was really showing dirt and grime, and he ruled it out. It’s been my experience with light “leathers/vinyls” that some repel better than others. (Couches/chairs etc). (I also changed away from OC-FWIW).
Edit: I believe this is the post you are referring to:
https://www.rivianforums.com/forum/threads/ocean-coast-interior-after-extended-mule-use.4470/
Also this Redit guy is tinting his roof so even though the lighter seat does not save your noggin, it may save your bacon.
