If your AC is weak, make them check for a leak
clockwork crane
San Francisco Bay Area
I got my R1T in September of last year, in the middle of a heat wave. I noticed even at delivery that the AC seemed a bit weak, but I figured it was probably just fighting 100F+ external temps.
Over the next couple of months I kept noticing that the AC wasn't doing a very good job, and after November or so it was just not doing anything. When I brought my truck in a couple of months ago for other repairs (including a non-working air vent), I asked them to take a look at the HVAC and refrigerant also. They noticed it was undercharged, and recharged it.
At this point I started to get suspicious; why would the refrigerant be undercharged? Was it leaking somewhere? Sure enough, over the next month or so, the AC started to weaken again. When I brought it back in last week for another fix, I told them to take another look at the refrigerant. And sure enough, they found a leak: there was a "rolled o-ring in the evap sensor"; they replaced the O-ring and the sensor too.
AC seems to be working fine now, though time will tell. Got a road trip to Arizona planned later; that will definitely test it. :)
So, if the AC in your Rivian is weak, and especially if it gets weaker over time, that's not normal; I suggest you get the SC to inspect it for refrigerant pressure and leaks. And in addition to wanting cabin comfort, it's an environmental issue: most automotive refrigerants are awful greenhouse gases, so the less they leak into the atmosphere, the better.
911.1 Guy
Juan
Melbourne, FL
2 Dam Many
Finance
If refrigerent leaks out, you have a leak that has to be fixed. Filling it will only be temporary.
clockwork crane
That's why I took it back in as soon as I realized that the AC was getting weaker again. I still can't figure out why they didn't check for a leak the first time, since it would be weird for the refrigerant to be undercharged at the factory. Possible, I guess, with Rivian's build validation issues. But weird.
EVTrukHog
F150, Explorer, Corvette C6
i had the same pinched O-ring and A/C problem within 35 days of getting my truck last fall. This is a thing on some builds.
nc10
South Carolina
R1T LE, EV6 GT Line
Mine has been in the SC twice to fix a leak. I'm concerned it is failing again, but hard for me to tell for sure in cool weather
av8or
Randall
FedEx Retired
Mines going in in a couple weeks for AC repair as well.
madgrey
Allan
Fidalgo Island, WA
Hardware Design Verification
"A rolled o-ring" is the same issue attributed by the SC advisor about my suspension leak. There seems to be a cack-handed person or robot putting these things together.
clockwork crane
Update:
Air conditioning performed well for the entire road trip, no more issues.
I have also noticed that the truck can now maintain DC fast charging at higher kW for longer and at higher states of charge. On previous trips I would sometimes hit DC charge rate limitations with the message "Limited while battery is cooling", even in relatively cool weather (40F-55F). Now with the AC fixed, I haven't ever seen that message again, even after fast charging multiple times in one day. There are of course the usual station-related problems (thanks EA!), but the truck itself is performing well.
BooneRiv
Jason
Boone
Tacoma, Tesla MS
I had the exact same issue. The Atlanta SC found this right away. They didn’t attempt the band-aid fix of only recharging it.
shift4
My truck struggled in the heat,
Like a desert in the backseat.
I brought it to service the next week
So they could take a peek.
They noticed the cooling was deplete,
So they filled it back to complete.
I thought the problem was obsolete,
But alas, the cooling was still meek.
The situation looked bleak,
But a solution I was determined to seek.
Once more to service, refusing defeat.
Again, they gave it a tweak,
Finding an o-ring that had been beat.
So if your AC is weak,
Make them check for a leak!
ADKR1S
Adirondacks, NY
2023 R1T , 2023 Toyota 4Runner, R1S Preorder
VP of Sales
prestapost
Pullman, WA
2019 RAM 1500, 2022 Rivian R1T
Anyone know if a non-Rivian service place can recharge or check for a leak? Mine worked last summer, but appears to be dead now. Service center is 300 miles away.
Kitsap, WA
I learned today if your fan pressure is low, and you don't want recirc, you can crack a window and it'll blast instead of pressuring your damn ears.
Christopher
Christopher
South Florida
Tech
Doubt it's something a mobile service can do but worth asking. Did it slowly get worse? Any local shop to diagnose and fix HVAC system is going to make a 300 mile trip worth it. They'll need to evacuate the system, perform a pressure test, if that fails then find the leak and fix it, then recharge. Not cheap! And if it's not even a leak they won't have access to Rivian parts.
