fill the front trunk with cash and take an R1T to Hutchinson for the only real road legal beadlocksI don't think these wheels would stand up to hard off roading. I'm still waiting for someone to release wheels specifically meant for the Rivian with real bead locks, before I plonk down money on anything aftermarket. I don't need or want to make concessions.
These are cheaper than some of the other options people have posted on the site. Though that's probably not going to be true since the Rivian can't fit smaller than 20s unless the brakes are changed out too. Reached out anyway.fill the front trunk with cash and take an R1T to Hutchinson for the only real road legal beadlocks
https://www.hutchinsoninc.com/rock-monster-wheels/
Most tires in this size range have a load rating of at least 2,500 lbs. So, even with payload, they will hold the Rivian's weight just fine. Rivian stock all-terrain tires have a load rating of 2,760 lbs. The tires I have on the truck are load rated for over 3,750 lbs, so I could pretty much handle two Rivian's on these tires.Sorry if i missed this in your thread, but what tires are those and are they rated to support the 3.5 ton (7100 lb) Rivian?
Drove another 40 miles today, mostly city street driving in the 40-45 mph range, several up and down hills and shockingly, did not reset the trip meter from the prior 50 mile drive noted above, but my miles per / wh jumped all the way up to2.35. Wish I had reset it as that's the end result, being weighed down by the prior 1.85 figure. So, guessing, it had to be closer to the 2.7 to 2.8 today alone, which just doesn't seem logical. But, 90 miles now and it's at 2.35, which I'd be happy with on it's own. Certainly doesn't appear to be any range hit with these wheels and tires.Put in about 50 miles today. Standard trip. Was 106 degrees out again today, so AC was full blast. I've been averaging between 1.75 and 2.0 miles (on a good day) per / wh. Was right at 1.85 miles per / wh today. Of the 50 miles, roughly 60% of it was on the freeway at 70-75 mph. So, if there's any measurable hit in range, it's pretty minimal. If I had driven more conservatively, probably could have gotten 2.0 mi/wh. Expected to see more, especially considering these tires are heavy duty tires that weigh a good 12 lbs more than the stock tires. So, even with 48 extra pounds of rolling mass, no significant impact to range noted with the fitment reflected above.
Waiting on the TPMS's to show up to install the second set of wheels / tires. Will update once those get those on there.
And what brand and model are they? They are nice aggresive looking tires.Most tires in this size range have a load rating of at least 2,500 lbs. So, even with payload, they will hold the Rivian's weight just fine. Rivian stock all-terrain tires have a load rating of 2,760 lbs. The tires I have on the truck are load rated for over 3,750 lbs, so I could pretty much handle two Rivian's on these tires.
Quoted me "$5-6k each". I'm assuming that's per wheel. A bit rich, but I've told them that I'll be interested when they can bring it down to that per set of four.fill the front trunk with cash and take an R1T to Hutchinson for the only real road legal beadlocks
https://www.hutchinsoninc.com/rock-monster-internal-double-beadlock-system/
Versatyre MXT/HD LT 285/60R20 Load F 12 Ply MT M/T MudAnd what brand and model are they? They are nice aggresive looking tires.
Not bad for what at this point would be one offs. that’s a ”if you really want it we’ll make it” price if I ever saw oneQuoted me "$5-6k each". I'm assuming that's per wheel. A bit rich, but I've told them that I'll be interested when they can bring it down to that per set of four.
Wonder what volume they’d need to get to that price point. Starting to be enough R1Ts out there that a group buy because at least remotely plausible.Quoted me "$5-6k each". I'm assuming that's per wheel. A bit rich, but I've told them that I'll be interested when they can bring it down to that per set of four.
Great documented effort here. Did you get a solid efficiency rate with the 275/60s? You mentioned it was combined at first with some at 1.85 mi/kWh. I'm looking to go to 275/60 in a scorpion all season.EDITED ORIGINAL POST TO SHOW FITMENT WITH NEW 275/60/20 Pirelli Scorpion tires. 33" tire, same circumference as on the 21 and 22 inch wheels from Rivian. In my own opinion, this is the size they should have stuck with. Fits the truck / wheel wells much better. The 34's, for me, just dominate too much of the wheel well space. See added photos in OP.
In my drive yesterday, over 100 miles, came home with a mi/wh at...........1.85!! So apparently no change.Great documented effort here. Did you get a solid efficiency rate with the 275/60s? You mentioned it was combined at first with some at 1.85 mi/kWh. I'm looking to go to 275/60 in a scorpion all season.
