kizamybute'
- Joined
- Oct 17, 2021
- Threads
- 80
- Messages
- 1,180
- Reaction score
- 1,997
- Location
- Los Angeles
- Vehicles
- This one, that one and the other one.
- Thread starter
- #16
I've certainly considered that as well and may very well do that on the next set. 275/60/20 is what would put you at 33.I congratulate you. Very informative. I, like you, have done a bunch of tire size research and commend you for outside the box thinking. I'm probably going 1" smaller in dia. to more match the 21s dia (better range and looks), @33". But those would be road tires. The 20 ATs are all I need for sand in the OBX.
What are you doing with OEM 20" wheels?
I'm happy with the fitment of the 285/60/20 shown, but if going with the 18mm offset, the 275 would assist in providing even more clearance, both in width and height. As noted, the tread lines up about even with the outside of the fender flares. A 275 would bring it in a little and provide roughly 1/8th inch more height clearance. Between the two, probably could be safe in the low suspension setting.
Have found a few 20mm wheels that have potential. So, if I choose to make a change, knowing me, I likely will just for fun, will probably select a 20mm offset wheel with the 275/60/20. That would narrow up the outside (bring it in) by 0.2 inches, in addition to the 2mm that would be gained from the 20mm offset. Between the two, about a 1/4 inch further in than this setup is.
In standard and high ride height, I like the current fitment, but for those that want to use low/lowest, that 1/4" would make a notable difference.
Am keeping the stock 20's in the garage. I always keep the original equipment until I sell the vehicle.
