evhelphub
Wes
evhelphub.com
Finally, an article that talks about more than just speed!
Mentions highway range test and cabin noise.
Tested: 2023 Rivian R1T Dual-Motor Performance Doesn't Sacrifice Much
Although less powerful than the Quad-Motor, the R1T Dual-Motor still provides neck-snapping acceleration; composed handling; and a classy, comfortable cabin.
https://www.caranddriver.com/review...an-r1t-dual-motor-performance-by-the-numbers/
VSG
R1T LE/RB/OC/20
Our 75-mph highway test revealed the Dual-Motor can travel 280 miles on charge—a bit of a letdown considering the Quad-Motor rolling on the same tires returned an identical number and that the number is significantly shy of the Dual-Motor's EPA estimate.
So once again C&D is promoting its misleading take on range and once again they imply that Rivian is fudging the numbers.
Remember when they first tested the R1T and claimed a range of only 220 miles on the 20" wheel? There are thousands of posts here with a combined experience of over 1 million driven miles which totally contradicts that. They were just wrong - that's what happens when you invent your own "real world" tests.
The reason they get a different number than the EPA rating is because they test in different conditions (among other things). Duh, of course they get a different number. The EPA rating is reproducible, so if you use the same conditions you will get the same results. The EPA numbers for the R1T are not a lie, they're a fact. The EPA rating is a standardized test that is useful as a reference number because it's done the same way for all vehicles. The C&D number is not useful at all.
My R1T with 20" wheels gets about 315 miles in conserve mode, and about 290 in all-purpose. That's my reality over 12k miles in wildly varying terrain and conditions. So when I read an article that tells me I'm wrong, and at the same time claims to give me the "true" range and claims to debunk the "official" numbers, I call bullshit.
madgrey
Allan
Fidalgo Island, WA
2026 R1T, 2016 Miata, 2015 Viper
Hardware Design Verification
I think C&D points out that it doesn't match the EPA rating simply because it didn't in their test. Not because it should. I didn't see anywhere that they said the EPA lied.
Real world numbers are useful to me, but we need more than one data point. I look forward to more tests besides C&D. How the vehicle performs on a chassis dynometer in a lab isn't really that useful to me without some real-world data to back it up.
R1Maybe
Model 3
Most people care about range primarily when driving a long distance at high speed. The EPA range does not capture that metric well. Range at 75mph is the number most people really care about.
If the dual motor does not increase range at high speed then for my purposes it doesn’t matter. When puttering around town I’ll never run into range issues so I couldn’t care less about low speed range.
The EPA test absolutely has value due to the consistency but a version of that test focused on 70-75 mph would be far more useful.
SASSquatch
Washington DC
BMW i3s Ford C-Max Hybrid
Semi-Autonomous Yeti
Honestly - EPA or no EPA I am not shocked by this.
Why?
Bosch has been designing motors for over 100 years.
Rivian has been designing motors for 100 days?
The Bosch motors are probably as efficient as you can get.
madgrey
Allan
Fidalgo Island, WA
The Dual motor variant doesn't weigh much less. Rivian didn't add new aero to lower the Cd. So, why would we expect the range to be significantly different?
I thought the main reason for the dual motor variant was to offer a lower priced vehicle.
madgrey
Allan
Fidalgo Island, WA
Dual motor is 400 lbs lighter
Not according to the C&D article:
The Dual-Motor tipped our scales at 6914 pounds, 122 fewer pounds than the Quad-Motor. Most of that weight loss can be attributed to the Dual-Motor having a tire-inflation kit instead of a full-use spare.
I thought that 400# number was questionable. What's the source?
EDIT: Added C&D quote.
usofrob
Robert
Tesla 3, lotus Elise
MBSE
Supratachophobia
Ohio
S
You forget that while reproducible, EPA isn't a useful metric for real world unless you are using a multiplier based on conditions. 280 miles @ 75mph is actually a much more meaningful metric to me. Just because they show that, doesn't mean it's a hit piece.
usofrob
Robert
MBSE
It doesn't seem like a hit piece to me. It just seems like they aren't doing a full investigation of the Rivian. They clearly didn't have a lot of time with it, but they also didn't seem to provide much extra information unique to Rivian. This is why we need more enthusiast reviews like Out of Spec or simlar.
When they tested at 220 miles, they didn't share all the details like the enthusiasts do. And because of the discrepancy in their testing (220 with 20" and then 280 with 22"), I wouldn't trust their 280 miles either. 280 miles at 75 mpg is still pretty good.
Eeyore
Bruce
Retired Union Electrician
Those numbers pretty much match my experience with 20's.
Verified by multiple round trips between Keizer (Salem) Oregon and Shoreline, just north of Seattle Washington. Stupid navigation usually tries to get me to stop and charge even though it's only 227 miles driving. Last time I arrived with over 50 miles left and I probably averaged 75 mph on the trip.
