Sgt Beavis
Rick
Overpaid Computer Nerd
Without a doubt my favorite line - and something I will repeat countless times to anyone that joins a ride in my R1T
" The upholstery is 100% vegan leather, made from only the finest vegans." :CWL:
I’m right there with ya..
KeithPleas
Keith
Mercer Island
Lexus GX, Porsche Boxster, R1S LE
Not gonna lie, I chuckled.. ?
He had a bunch of those buried in there..." the gimlet-eyed R1T"..." it can haul off like a spooked tuna"..."and wade through 3 feet of water. Most pickups can do that trick only once"..." strangely light and heavy, like an aluminum anvil".
I thought it was a unique take and an enjoyable read. Mission accomplished.
Sgt Beavis
Rick
Me too their sense of humor I find lures me in. “Most pickups only can achieve that once” after picking up their bumper off the ground behind them… ?
Man, I live that. I’ve recovered 4 vehicles from various situations in the Colorado Rockies. I’ve pulled one unmodified Tacoma from a lake that it tried to ford. I pulled 4runner with street tires out of a snow bank it should have never attempted to cross. One time I recovered a Willys Jeep that fell off a cliff edge and was saved by a tree. I actually the part of it falling off the cliff on video.
Blur1t
Andy
Mason
R1T Launch, Subaru Cross trek
Enrolled Agent
I’m there with you, My old Rubicon pulled many a fellow out of some sticky situations. You only live once, as long as it’s just you in the truck, it’s more fun on the edge of your seat…. ? Your wide body Raptor does not miss a branch on every trail but sure makes it look easy!
Issaquah, WA
2016 Toyota 4Runner Limited, 2015 Subaru Crosstrek
Physician
WSJ:
Put simply, the R1T’s own weight limits its ability to do serious work. With a gross vehicle weight rating of 8,532 pounds, the R1T qualifies as a heavy-duty truck, like a Ford Super Duty F-250. Yet its payload is 1,764 pounds, compared to the Ford’s maximum 4,500 pounds.
The problem may also be expressed as a matter of energy density. Fitted with the all-terrain Pirellis, the R1T has an unladen range of 267-283 miles. But if you hook up a horse trailer with a couple Percherons (11,000 pounds towing capacity) your range could easily be half that. What if it’s 10-below outside? You could always harness the horses to the front bumper, wherever that is.
I’ve never needed 1000+ lbs of payload, nor would I ever ever tow a horse trailer (I’m towing a raft, that’s it). So this writer clearly doesn’t understand that this isn’t marketed as a work truck. One look at any promotional material from the manufacturer demonstrates that. If you’re buying this truck as a contractor or lineman expecting it to replace your Silverado or Super Duty, you need a reality check.
dleepnw
Rivian, Toyota, Lexus
Key takeaways
-it’s heavy
-it’s inefficient
-the tonneau jammed
-bad panel gaps
-poor fit and finish
-UI froze twice and required hard reboots
-driver+ didn’t work
all of this i can live with except the buggy UI. they gotta get this sorted out ASAP.
Diddy123
Montana
Acura MDX
I'm actually more concerned about the things that need to be made correct from the factory, like gaps and fit and finish. UI can be updated OTA, but the physical issues would require a lot more effort t fix after the fact.
KingofThorns
Justin
New York
2022 Lexus GX 460
Attorney
Especially if there are no physical controls in the vehicle. I am not opposed to there not being any physical controls, but I would expect that the UI is second to none in that case. If the UI is not up to par, then there needs to be physical controls so you aren't left with a $70K brick.
LaunchGreen
Range Rover
Their experience with the UI is exactly the same as mine at the L.A. first mile. Couldn't even adjust the volume, screen froze, maps very slow, switched screens without being touched, etc, etc.
I'm pretty confident it's going to be terrible for 1-2 years (but improving) as it's obvious to me that they built the entire system assuming they have a constant, low-latency internet connection at all times which is not how vehicles (or the real world) work. I'm sure it's amazing on their emulators in the office.
I think there are quite a few variations of software in the wild. RJ mentioned that they push out OTAs weekly, so it makes sense that there may be some fragmentation. I only say this because my experience driving it was quite different. The UI was responsive, all features (except the tonneau) worked as I expected, including Driver+ Highway Assist. Even the cameras were better than I had seen on other reviews with good (not great) resolution and no lag or stutter. I have terrible cell reception at my house, but there were no issues with Spotify or maps in my test truck.
All that said, they should be putting their best foot forward on a customer facing vehicle.
LaunchGreen
Range Rover
How was the internet connection when you were using it? The trucks worked fine in L.A., but I intentionally stopped on the track when I saw that we had 1 bar, and tried to use it and it failed HARD.
On a good day I get 2 bars (Verizon) at my house. Here is a shot from that day.
Rivian R1T R1S WSJ R1T Review 2021-12-10
sevengroove
R1S Launch Edition
I can see how maps and Spotify would stutter with a poor internet connection, but why should local functions like volume control, vents etc.? The OS itself should not have to rely on the internet for functionality, just like using your phone in airplane mode, and apps with local functions shouldn't stutter. I'm thinking the issue is something else.
ads75
Reading, Pennsylvania
Utilities
Really quite exhausted by the constant complaints about EV range. If you drive a vehicle hard, they are naturally going to use more energy than if you drove at a consistent pace like you would for a long trip. If you can get within 5/10% of the EPA combined range at a consistent 70 mph in good weather, that should be adequate for determining if the vehicle is going to work for you.
The complaints about reviews making repetitive comments about EV range when driven hard are understandable, but also help set an expectation for people who have never driven an EV. This might be the first review (or only review) they read about a Rivian. There are probably a decent amount of people who have never heard of Rivian (or Lucid or most other startups) and aren't familiar with potential hits to range like performance or weather.
