eggpaul
Paul
Sierra Madre, CA
Business Owner
The 491 is the actual result achieved on the dyno test.
Numbers are "derated" by a standard 30% (multiply x .7) to better reflect real world results.
If the manufacturer elects to use the 5-cycle test, they can apply a different value with sufficient documentation. Rivian uses 28% for the R1T and 30% for the R1S from the raw (unadjusted) test results.
What's the dyno test? How did the vehicle go 491 miles on a charge? That's great.
sub
Rivian R1S, Tesla Model 3
Hmm. Actually find this a little troubling.
For me, "cold weather" amounts to mountain driving, which often means accumulated snow on the roads. So I'm going to take a nasty hit from the cold, a nasty hit for the AT (3PMSF) tires, and a nasty hit for staying out of conserve mode because it seems pretty dumb to choose 2WD when plowing through snow...
Anybody want to venture a guess as to the actual range capacity with cold weather AND the AT tires AND using (at least) all-purpose mode? Really need to get 200+ miles but a 40% hit due to cold alone means that's impossible? No bueno.
Cold weather knocks range, but in my Model 3, snow takes it to the absurde.
Here is a drive I logged during a snowstorm last winter. The roads were covered in 2-4 inches of fresh (all 2-4" had fallen within the last hour) snow.
Consumption was a massive 813 wh/mile. At that level of consumption, my 310 miles of EPA range was only actually good for around 90 miles in the snow.
Rivian R1T R1S Rivian technical nuggets gleaned from EPA application docs Screenshot 2021-09-28 2.42.31 PM
Note it was 16F at the time. My average consumption 16F weather is around 350 wh/mile. So the snow more than doubled the already elevated cold weather consumption.
Rivian R1T R1S Rivian technical nuggets gleaned from EPA application docs Screenshot 2021-09-28 2.40.14 PM
yizzung
California / Colorado
R1T | Audi allroad
Tech
Here is a drive I logged during a snowstorm last winter. The roads were covered in 2-4 inches of fresh snow.
Yikes. What kind of tires?
yizzung
R1T | Audi allroad
Tech
Also, it's not like 2WD is a death sentence in winter. Most cars are 2WD and they do fine.
Tooling around a plowed city street is fine but It is close to a death sentence when crossing the mountain pass on I-80 through the Sierras in the middle of a snow storm.
Speedrye
NC
Commodore, Supra, FJ Cruiser
WTF I want to know is how is a truck more efficient than a shorter and theoretically less weight SUV. Did we ever get that answer?
I suspect it's aerodynamics. With the bed cover, the air tapers off better on the rear of the truck than the blunt tail of the SUV, leaving it more efficient due to less drag.
Speedrye
NC
Wind resistance isn't factored in on the dyno since it's just sitting on stationary rollers. Pretty sure that's the bulk of the correction factor applied, especially since these are blocky vehicles.
crashmtb
Man oh Manitoba
For me cold weather is -30.
And most of my long distance driving happens in winter. Will be interesting to see how truckasaurus Rivian does
Reactions: Rad
DucRider
Gary
ORegon
Polestar 2, Ioniq, R1S
Wind resistance is factored in when configuring the dyno settings:
Rivian R1T R1S Rivian technical nuggets gleaned from EPA application docs 1632861342984
yizzung
R1T | Audi allroad
Tech
Sounds like you might to need to mount a lightening rod to the top
roth_nj
MA
Jeep Gladiator
mechanical engineer
thank you and that makes sense then for drag through the air, etc
eggpaul
Paul
Sierra Madre, CA
Business Owner
So All purpose mode would get a little less range than Conserve but more than Sport .
