R2 Demo Drive - Driver's Screen Too Obstructed
ClayCollins
Clay
Houston, TX
2022 GMC Yukon, 2012 Jaguar XF, 1963 MGB
Retired Mechanical/Petroleum Engineer
Took an R2 demo drive last week in Houston and really liked the R2. My only gripe (other than the black interior in the Houston heat) was that the driver's screen was overly obstructed by the steering wheel when I set the seat and steering wheel height to a comfortable position. I'm 6' tall and a pretty normal build, but I had to elevate the steering wheel to nearly the highest setting and lower the seat more than I liked to see an adequate amount of screen real estate. This inclined my arms upward at an awkward angle. Curious if anyone else had this issue.
They should consider linking the screen with the steering wheel so that the screen moves up and down with the steering wheel. Part of the problem is the flat region on the steering wheel from about the 10:00 to 2:00 position which cuts across the upper 1/3 of the screen. Rounding this off would help quite a bit.
GregBOS
Greg
Boston
Nissan Altima
I'm 6'1 and could see most of the screen but not all. For example, time and battery info were blocked even though I tried different steering wheel positions.
I'm 6'2" and could see the entire screen really easily.
sparked
R2 Reservation
Same issue for me. I made it work for the drive, but not sure how comfortable I was. Will probably demo drive again to double check that I can live with it.
MalianJ
Varoujan
San Jose, CA
2018 Audi SQ5, 2023 Kia Telluride, 2012 Acura MDX
I found that the seat positioning matters. took me a few demo drives but I was able to find a comfortable set up and still see most of the screen.
a9967
Polestar 2, Hyundai Palisade
That's almost every car I've ever been in. Not unusual at all for top corners of the driver display to be a little obscured. You get used to it in about 5 minutes.
Parallax
Andrew
Indianapolis, IN
R2 Reservation
Phone book in the seat. You just need to be taller lol. Just kidding. I'm 6'4" and found a good balance only losing the very corners of the screen. Perfectly livable.
GABarber
Southern California
Tesla Model Y
Same here - this screen should be height adjustable. Also the main screen could really use a tilt option - if you have bifocals its hard to have the entire main screen in focus. On tesla there are some after market kits to allow it to be tilted more toward the driver. I also notice that visibility of images of cars and pedestrians near the car (especially to the side and rearward) is much less helpful than on the tesla - and when shifting the car to backup the display stopped illustrating nearby vehicles for some reason.’
Lysdexic
Lake Norman, NC
Gen 1 R1T, ‘16 Model X, ‘04 Tundra, ‘04 Jeep TJ
I am 6’2” unless I have had a few beers the night before and dehydrated. Then I am 6’1”. I noticed the same thing.
That said, maybe I should test drive with a hangover.
