R1S flat towing behind an RV?
socaladam
Aj
nocomment
I searched but could not find my answer.
Anyone know if the R1S can be flat towed behind a RV?
Brian Gase told be that this is possible. You will be able to disengage drive from any of the wheels.
skyote
Austin, TX
gdenon3
George
New Hampshire
R1T - Preordered, 2020 XC60 T6 Inscription, 1985 BMW M635CSI, 1970 BMW 2002
Will you be able to charge the car by towing it with an RV?
EE Retired
There are 4 motors each driven by its own inverter, 4 gear boxes and 4 wheels. Turning off all the inverters decouples all the wheels and prevents them from delivering or absorbing torque. The vehicle is in the BEV equivalent of Neutral and provided there is a properly engineered tow point (i.e. one designed for long range towing - not something like the kluge on the Tesla Model X) there is no reason why it couldn't be towed.
A vehicle being towed is like a vehicle being rolled down hill in that there is a force pulling it forward. Thus regenerative braking (which charges the battery) could be enabled in a vehicle being towed. But Rivian will not do anything to enable this. In fact I would think they would be more likely to do something to disable it by sensing load on the tow point for example.
BillArnett
Bill
Emerald Hills CA
Rivian R1T; Tesla Model 3 (Cybertruck on order)
One knowledgeable Rivian guy I talked to at the Mill Valley event assured me that it is indeed possible to charge the battery by towing.
EE Retired
Yes, it is quite possible as I explained in my last post. It is just not something you would want to do.
BillArnett
Bill
Emerald Hills CA
Right. I can't think of a circumstance when it would be useful. If the battery is dead and you're some distance from a charging point you could tow for a while to charge the battery enough to drive the rest of the way normally. But it would be more efficient to just tow the whole way.
skyote
Austin, TX
Mamy states require braking assistance from the towed vehicle, and it would make a lot of sense to have the Rivian regenerate during braking & help the tow rig stop in the process.
Doing regen while towed under constant speed is a waste.
CappyJax
Subaru Forester
Actually, it would be free energy. Instead of using the friction brakes of the towing vehicle, you could use the Rivian regen braking to slow both vehicles and recharge the battery for free. You could almost recharge completely coming down something like the Ike.
EE Retired
It's probably worth mentioning here that Tesla's position is that this (dinghy or any other kind of towing) is something one must not do to their vehicles. I have often wondered why that is and, of course, in the current context, whether Rivian will come up with the same caveat.
skyote
Austin, TX
Rivian has confirmed multiple times that their vehicles can be flat towed.
StevieD
Stephen
Florida
2019 RAM Longhorn, Cancelled R1T Reservation
Retired - Living the Dream!
I'm a full time RVr so flat towing is important to me. Key considerations to flat tow my R1T "TOAD" include:
1. Attachments: It would be a huge plus the design had removable covers to hide the attachment points for the towbar, electric harness, breakaway line, and air brake hose (I have a 45 footer). There are several manufacturers that make adapters for the TOAD. It would be nice not to modify the frame or cut the front to place the removable adapters. A strong front cross-member would also eliminate the need for an external one.
2. Supplemental Braking: Most Diesel RV's use air brakes to stop the "house". Systems like AIR FORCE ONE "AFO" provide the ability to extend this to the TOAD to support proportional braking as well as breakaways. AFO creates vacuum for the braking system to reduce required braking force and a piston located on the brake pedal to perform the braking. Design considerations should at a minimum consider the placement and interconnection routing of the required components and perhaps integrate the functions completely within the R1T design.
3. Electric Harness: If the harness is incorporated into the design, under-frame wiring and diode-ORing for the rear lights (left, right, brake, tail) could be avoided. While not needed, I prefer a 7-pin connector to extend a few other features including charging my TOAD's battery.
Battery charging while towing would be great as long as it doesn't drag down my RV's performance too much. If supported, it would be a great idea to have the ability to disable it.
Rivian R1T R1S R1S flat towing behind an RV? 66A4C30F-37FF-45C5-8F92-57F40E267CB3
Rivian R1T R1S R1S flat towing behind an RV? 18D50EED-322E-4E88-83AF-A6D00675052F
Rivian R1T R1S R1S flat towing behind an RV? 47411F00-FF1D-4B06-915E-F047D8BD1EDE
CappyJax
Subaru Forester
Ideally you would use the Rivian regenerative breaking to slow down and maintain speed going down hills. If your RV and the Rivian weigh 10,000kG together, then the energy needed to slow you down from 55mph would be around 1kWh. So, you wouldn't want to charge the vehicle while being towed, but rather allow the regenerative braking of the Rivian to slow both vehicles down and maintain speed on hills to charge the pack with otherwise lost energy.
StevieD
Stephen
Florida
Regen charging would be great if it doesn’t hurt my RV mileage (45 footers are diesel hogs!) Or if it could be disabled if not desired would be a great feature.
