Here's what I tow now with my Avalanche, and hopefully with an R1S s00n - Rinker MTX 220 wakeboard I/O
Let me guess… The connector at that charging stall didn’t fit properly into your truck?
How long does the battery last in the GS22E? Are you able to fast charge it at an Electrify America and how long does it take?My new R1T towing 100% electric Nautique GS22E
Thank you for sharing. What does this setup weigh? With the single axle I'm guessing it is pretty light. I have a Yamaha sx230 and trying to figure out whether or not to sell my Cummins.Sea-Doo Switch, 21'. I was pulling a 30' pontoon boat in the past and getting about 1mi/kWh. Same it seems for this boat, more or less. 330 miles total and one leg had 113 miles between charges. I was doing 60mph on that stretch, but 20 miles out it looked like I had extra so I sped up to 70mph. Came in to the charger with 4% battery
My best attempts at measuring efficiency on the flat sections:
75 miles an hour, 0.74 mi/kWh
70 miles an hour, 0.80 mi/kWh
65 miles an hour, 1.00 mi/kWh
60 miles an hour, 1.20 mi/kWh
You get up to 3 hours of active watersports time, slow idling and neutral add to that time. It depends on how much ballast water you pull in and how many people aboard and how large the wave. This use case works for most people. Charging is CCS and as such you can plug in anywhere you can charge your Rivian.How long does the battery last in the GS22E? Are you able to fast charge it at an Electrify America and how long does it take?
Actually that was 2021 pricing, 2022's typically more like $330k.Waaaahat???? $300K ?????
So at $330K that works out to $15K/foot... yikes!Actually that was 2021 pricing, 2022's typically more like $330k.
Would love to hear your feedback on the GS22E, please. You wakeboarding and surfing under full ballast? How’s slalom pull speed and consistency? How long can you run her daily? What is the charging setup and how would you do so in a lift? Cheers and well played.My new R1T towing 100% electric Nautique GS22E
The battery adds +1k lbs right at the transom so right out of the box the E makes a better wave then the combustion version does. However if you run full ballast and 8 people your run time will be less, more like 2 hrs on throttle (again, off throttle and idle don't use much power at all, so you can be out for 4 hrs with a little down time, switching riders, etc...). Charging is CCS, so whatever you can get to your dock, depends on your location. Most customers do a 48a L2, but some do a 25kW L3, and we have 3x 100kW chargers in marinas in Tahoe. Battery is 124kWh.Would love to hear your feedback on the GS22E, please. You wakeboarding and surfing under full ballast? How’s slalom pull speed and consistency? How long can you run her daily? What is the charging setup and how would you do so in a lift? Cheers and well played.
