ndmiller
Noah
Atlanta
23 R1T Silver (The AG)
Retailler
You need to make sure you fully turn off traction control first as well for even better results.
So the family could all puke on me? Once a 7000lb vehicle is under 4 seconds, there are no better results measured by anything but a stopwatch. My Boxster would it in 4ish with significantly more violence and amazing sound with the top down, but silence under 4 is golden.
tkauftheil
todd
Missouri Valley
2025 R1S Dual Standard
network/security engineer
For lunch …er launch control, at what rpm will it launch at? Does it keep it on thru 7k rpm, or maybe 20k? 50k rpms? I only ask bc launch control on an EV is sort of pointless. Like selling ice to Eskimos pointless.
Growing up the concept of launch control was to keep the rpms up and shave a microsecond off of letting the clutch out. In an EV all the power is instant as soon as the go pedal is mashed. So adding LC on an EV adds a step. …but what do I know.
On a more serious note, I have looked everywhere and cannot find a high flow race exhaust for my R1S. Any recommendations?
Kelvn
Irvine
setup Siri Shortcuts works for me
This update sounds very handy, but ironically, the winter range update will hit us just in time for spring :facepalm: -- the most handy thing about a watch app for me would be a remote button to open the frunk whilst I am carrying groceries back to the truck, or better yet, siri integration to accomplish same thing via voice; I wonder if that will be an included function.
Considering the watch app is coming out I dont know if this will be relevant anymore. but if you scroll up on the watch home face, you open up the widgets screen, you can add Rivian Controls to the widget screen. This should still base off your phone being connected.
I enabled the finger tapping feature (settings > gesture > double tap on, in teh smart stack settings chose select instead of advance)
Now when i'm on the watch home screen, i double tap my fingers, it opens up the widget screen, since the first option is my liftgate toggle I double tap again to select and it opens and closes my trunk.
In your case if my hand is free enough.
  1. I raise my hand in a way to wake the watch
  2. Double tap my fingers (pause for 1 second to ensure screen and watch is ready)
  3. Double tap again and the trunk opens.
R1TBrett
Brett
R1T | 993
I have no idea what Rivian will include for a launch mode (suspension rake, F/R power distribution, etc) but, there is definitely a ramp up to full throttle curve applied to all ICE and EV vehicles with fly by wire throttles. There likely will be some optimization there.
Kelvn
Irvine
Its an EV, they don't have cats for you to need to update. You need to update your mentality on expectations. What you need is a high flow race dog. That will improve your Lap times.
Also, agreed on the launch control. The only benefit I see is if it puts all the settings you typically need to put to get the best launch automatically.
  • Sport mode
  • Suspension Lowest
  • Traction reduced
Then the rest is just nice to haves like the coaching, foot on both pedals, steering wheel straight, etc.
I would also see a benefit if it puts the suspension into a Launch specific mode like Lower front, back a little raised. Tesla does that with the S, no idea if it actually helps traction.
IGR
I make things
  • Sport mode
  • Suspension Lowest
  • Traction reduced
Don’t forget suspension in soft mode for greater weight distribution over rear axle.
Rivian Roamer
rivianroamer.com
2024 R1S Quad Large, 2025 R1T Tri Max
Adventurer
prepares the vehicle including suspension and motors to increase maximum torque from launch
iforbes
Ian
Connecticut
APRN
I see. You don’t understand a concept, therefore the concept is stupid. Thanks for opening my eyes. You are the best and I can’t wait for more insight so I can continue to learn from you.
Marchin_MTB
Marcin
2015 i3, 2011 Honda CRV.
Some strange HVAC behavior introduced in the last update. Fingers crossed they get it sorted on this one.
mkhuffman
mkhuffman
Thursday
