Closedquestion
George
The Dalles, OR
2024 R1T Forest Green Quad Motor Large battery
I bought a set of these from amazon. So far they have been great. I only need them when I take my SUP somewhere. I have the Thule Evo on the bed. They are pretty noisy and take about 15 to 20 minutes to put on or take off. Pretty simple mount ing design, a u-bolt is basically it. NO t bad for $159
Amazon cheap crossbars
Yossarian
SE Pennsylvania
I bought a set of these from amazon. So far they have been great. I only need them when I take my SUP somewhere. I have the Thule Evo on the bed. They are pretty noisy and take about 15020 minutes to put on or take off. Pretty simple mount ing design, a u-bolt is basically it. NO t bad for $159
Edit: add inquiry.
I don't know if the cost tradeoff is worth it. 15,020 minutes is way too long to put on and take off.
Seriously though, I'm considering the same crossbars for the bed of my R1T. I will only need them occasionally for pretty light loads and what I really want to try is rigging something to try to mount my Thule on them. They attach with u-bolts, which may a bit cumbersome, but should be secure. They also look reasonably well-built, and much like a lot of the third-party crossbars I've used in the past. Any reason not to go ahead and try these?
Supratachophobia
Ohio
S
Any reason these wouldn't fit on R1S? At least on the front two mount points?
Ohm Boy
OHM BOY
2023 R1T, 2024 R1S
Renewable Energy
[/QUOTE]
I might have mistyped. Otherwise... flex pricing!! That should add another 17+ pages of complaints. /s
Well, if you can’t take the responses, don’t post in the first place. ??????????
Yossarian
SE Pennsylvania
Both sets (EVBase and Amazon) arrive Monday. I’ll report back.
I think I may pull the trigger on these anyway. Amazon says delivery Thursday, so if your report is discouraging, I can just drop the unopened box at the local UPS store on Friday.
Supratachophobia
Ohio
S
Wonder what makes then so noisy? They look ovoid shape without a lot of sharp edges. And does it matter on noise whether you mount them front or rear?
Yossarian
SE Pennsylvania
You can't see the underside in the photos on Amazon, but my guess is that there is channel, like a T-slot, running from side to side used to attach the xbar to the mounting posts. If here is, the turbulence caused by the air past that open channel is probably the cause of the noise. Some crossbars have front and rear faces and must be mounted accordingly. May be the case here as well.
We'll know more when @Riv E In issues his comparison report.
Kachook
Geo
Houston, TX
R1S, Mustang Mach-E, Odyssey and former iX
You are going to LOVE them!!!! TRUST ME!!!!
They look AWESOME in person! You will like them!!!
Kenny, do you by chance know the total height with the crossbars and the 22" wheels? I am contemplating a set, but end up parking in garages in Houston on a semi-frequent basis. The vehicle may end up too tall with the crossbars. TIA!
wicked2112
Kenny
Salem Oregon
Subaru Outback & CrossTrek
Warranty & Product Integrity Manager - Yakima Racks.
In Kneel mode, I measured 73 inches. All measurements will vary based on you drive modes, air pressure etc.
Kachook
Geo
Houston, TX
Thank you for the quick response. I will probably need to remember to lower the vehicle before entering the garages as the lowest one is about 6'7", I think. Thanks again!
Riv E In
2024 Rivian R1S DM
UPDATE: both the EVBase and Amazon sets arrived. They are identical in every way. Do not buy from EVBase. I’ll be returning those.
First impressions (have not installed): Like the black color, like that they’re uniform width (unlike Rivian’s that are thinner in the middle), like that the ends don’t overextend like Rivian’s, appear to be more aerodynamic (thin along front edge, thicker in back), no Rivian whistling gap.
Hope to install later today. Hoping they’re quiet while driving.
Instructions state 220lb capacity.
iansriv
Thanks for doing this. As a totally disinterested party abusing the power of the internet (j/k) could you post photos, please. Also, could you try a couple of parkour moves to make sure they are sturdy; once installed. Cheers!
Supratachophobia
Ohio
S
Any idea yet the difference between the Amazon sets I ordered (posted above) and the ones you ordered? Besides $40 of course.
