kizamybute'
- Joined
- Oct 17, 2021
- Threads
- 80
- Messages
- 1,180
- Reaction score
- 1,997
- Location
- Los Angeles
- Vehicles
- This one, that one and the other one.
- Thread starter
- #1
Another not fun adventure using Electrify America chargers.
Went from L.A. to Vegas. Charged on the way. Used my head and just went straight to the 150 kw charger, knowing that Rivian's always seem to have issues when using the 350 kw chargers. Worked fine and was on my way.
On the way back, stopped at the same place and for whatever bright idea got into my head, decided to try the 350 kw charger, primarily to get a true comparison on charging speed from 10% to 90% since I arrived with 10% both times and would have been a fair comparison.
The 350 kw charger however, would only ramp up to 78 kw. Unplugged and tried again, same thing. Switched over to the 150 kw charger. Now that one wouldn't work. Went back to the same one I used earlier. No go. Error initiating charging each time. Rebooted the truck. Finally got a different 150 kw charger to work. It ramped up to 148 kw. However, it added only about 20 kwh and then shut off. Tried to plug back in and immediately got the error again.
My prior time using the 350 kw charger, I had all types of errors and it put the truck in Turtle mode. Have read several others having issues with these as well. More mad at myself since I knew better.
Finally, gave up at this location. Appeared I had just enough range to make it to Barstow and to the Rivian charger. I did, but just barely. I arrived with 1% left. Plugged in and not an ounce of trouble. Within 25 minutes, had the range I needed to get home and was on my way with plenty to spare. The Rivian charger ramped up as high as 212 kw.
Had I stayed at the EA charger, would have been there at least an hour to get the charge I needed to make it home. While I already knew this, guess I will say lesson learned again. Better off charging to 50-60% than trying to go to 90%. Instead of an hour to get to 90% to barely make it from Baker, I got about 10 minutes worth of charge before it failed, then 25 more minutes at the Rivian charger. So combined actual charging time was just 35 minutes breaking it up into two separate sessions rather than an hour trying to get it all at once.
Logically speaking, would seem that a single stop would be better, but that's just not the case with EV's. Almost always better off with two separate charges to 50-60% than one charge to 90-100%, by a good margin.
Annoying that the EA chargers failed with the Rivian AGAIN. That part wasn't my fault. But, need to just remember to always plan for two stops on that trip and save at least 20 minutes of total travel time.
Looking forward to Rivian getting their network built up, hopefully soon!
