Michelin Defender road noise?
saguaro
Brandon
seattle
I recently put on fresh Michelin Defenders on my R1T. 21” stock wheels and replaced some worn out factory tires. Odd thing is, above about 60 mph I notice a very distinct, and very annoying, harmonic noise/hum that wasn’t there before. I’ve had the balance checked (road force balance), alignment and comprehensive inspection by the service center. Nothing out of spec noted.
Anyone else encounter this after swapping to the defenders?
j33pownr
Doug
Raleigh, NC
I made the same change on my 21" and notice at 65-72mph there is a humm that is new. Im at ~2500mi on the new tires and will do it again as long as I get more than 22K miles on this set.
runwithscissors
XC90, MDX, R1S
I have the 20” Defender LTX and they are quiet, much more so than the stock Pirellis.
Need to replace my Pirellis but want something quiet like the LTX but the more aggressive sidewall like the Pirellis.
Jonjon09
Jon
2022 R1T Launch edition Quad
Let me know what you find! At the time I changed mine from the loud stock Pirellis last year, the LTX seemed like the best choice for a quiet, long-lasting road tire with a somewhat aggressive look. The main negative on those is the weight, they are some heavy tires...
Aardvark
R1S, Model 3
I swapped the original 20" Pirellis for Michelin Defenders last month (Gen 1 quad R1S) at 42,000 miles. So far I am not experiencing the noise you describe.
Greg Chick
Greg
Tehachapi Ca. 93561
diyplumbingadvice.com
Retired Plumbing Contractor
I recently put on fresh Michelin Defenders on my R1T. 21” stock wheels and replaced some worn out factory tires. Odd thin is, above about 60 mph I notice a very distinct, and very annoying, harmonic noise/hum that wasn’t there before. I’ve had the balance checked (road force balance), alignment and comprehensive inspection by the service center. Nothing out of spec noted.
I have 21" all 4 defenders, R1T large Batt, Quad with cover over bed and 2 cross bar racks. the only thing I hear is the wind in my door seals. I am sound sensitive myself, possibly because my hearing is impared, but maybe my hearing cuts out the defender pitch? I play the stereo if I want distraction and I do not listen to "Metal".
wicked2112
Kenny
Salem Oregon
Subaru Outback & CrossTrek
Warranty & Product Integrity Manager - Yakima Racks.
Agreed! I am almost 34K into mines and they work much better than the stock tires. I have 22"s.
saguaro
Brandon
seattle
Folks I’ve talked to with the 22’s say no noise which makes me wonder if it’s a 21” specific type of resonance.
mik34
2024 Rivian RS1
Just put on 22” Defenders. No noise, much better than Pirellis.
ifnh573
R1T, BMW X5
Management
I have 21" defender and I have the same issue. Especially when cruising, not excellerating hard/slowing down. It's very subtle low hum while having my foot on the excellerator keeping at constant speed. I can also feel it through the pedal as well. Sounds like an ICE engine only that it is very subtle.
What's strange is that if I switch to the conserve mode, the noise goes away and comes back when I switch back to all-purpose.
Inherent harmonics. Tread pattern and resonance chamber (internal volume). Not much you can do about it: turn up the music.
evlavista
smart fortwo ed, vw id4, ford f 150, vw beetle
I went the same route and never noticed any increased tire noise on my 23 r1s.
Eeyore
Bruce
Retired Union Electrician
No, I get the road noise you describe with my 22" defenders. The OEM Pirelli's were quieter.
