NDIrish
- First Name
- Chris
- Joined
- Jul 16, 2023
- Threads
- 6
- Messages
- 98
- Reaction score
- 134
- Location
- Gilbert, AZ
- Vehicles
- R1T
- Occupation
- Engineering Operations Manager
- Thread starter
- #1
Ordered in March arrived Nov 18 ... long wait;
Really super easy install with the instructions; Definitely a workout, but straight forward and great instructions.
ONLY issue was for the 13MM bolt next to Rear tire instructions say:
"Loosen most forward 13mm hex head flange bolt at rear plastic panel (just in front of rear tire). " I loosened the one "just in front of rear tire" but they really mean the first part "most forward". Had all the rest lined up and just had to get out of position grab the tools and adjust, no harm no foul. Didn't make the same mistake on the other side.
These things are HEAVY but was a decent install with my 15 year old helping. Nothing too difficult with 2 people. Only other hitch was 1 slightly stripped torq55 bolt that had me worried a minute, but we worked through it, got it off an on and torqued (maybe not the next time). was thinking what will I do If I can't get this one out?
Other TIPs: line up the rear first and tilt it in, there is an OEM panel lip you have to get past at a slight angle (If not you bump it and can't slide the assembly all the way forward), then next difficult is the center frame bolt. My son made sure the front stayed lined up while I tilted in the rearmost one watching the center torq55 bolt cleared ok. Then all seemed to just slide in nice and aligned. Placed 2 of the big body bolts in loosely by hand near the middle, then readjusted to finish then all. Tightened from the inside out, things start lining up much better as the parts are tightening (don't be frustrated if the forward and rear most bolts don't line up while finger tight, they pull into the correct position as you tighten the middles. This goes for both the steps and the sliders.
Overall I would do install it again. It was a solid half day; unpacking, sorting; removing OEM pieces, installing running boards, then the rock sliders (those were the easiest, used the roller jack lift assist method they suggested, it works well; the rear of the slider is much heavier, so position jack accordingly, near the rear middle bolts and ensure you can get to all 4 middle bolts while it's jacked up and then it's a breeze.
Fun weekend project, nice product (we will see how they perform); kids approved of them so far
Only thing I may do different: LEAVE the OEM Rail Clips on.... they said optional, so I removed them... but now where do I store them? Would have been simplest to just leave them on, 1 less thing to find a spot in the garage.
Happy they arrived in time for the long Thanksgiving weekend; will try some obstacles I have been avoiding while I wait.
