dfacto
- Joined
- Dec 21, 2023
- Threads
- 0
- Messages
- 15
- Reaction score
- 13
- Location
- SF Bay Area
- Vehicles
- R1S, Volvo XC60 T8 Recharge
- Occupation
- Research Scientist
Makes total sense. Thank you so much for detailed explanation and pics!OK, I think that's probably causing your issue(Using the paclock). To be honest you don't need to use the pin at all, once it's tightened and the lock is engaged there's no chance it's coming out. But here's some pics of what I'm talking about.
If you use the pin instead of your paclock between the adujustment range of the pin and the fact that it's slightly smaller diameter will allow you to space the rack out plenty to get clearance so you. don't need the tape.
This is the Adjustment I'm talking about, the red knob on the right. If you back it out you don't need to insert the rack as far.
This is the gap you end up with and it won't touch for sure. I've had three bikes on here driving them back and forth from the Bay Area to Salt Lake.
Here's the size difference to the full size hitch pin and the gap you get.
Hope that helps.
What are your thoughts on theft without using a hitch pin lock? I removed the Quikr pin altogether and use my paclock because the rack itself is $700 and would be an easy score...if not for the hitch tightener lock...which I worry even a non-lockpickinglawyer could Bic pen pick in seconds.
