inconceivable
- Joined
- Mar 17, 2022
- Threads
- 6
- Messages
- 76
- Reaction score
- 134
- Location
- Fairfield, CT
- Vehicles
- Rivian R1T
- Thread starter
- #1
I’m hoping to get the help of the community to figure out if some of the things I’m experiencing on my truck are problems with my specific truck or just the way things are. None of the items below have actually caused me any real issue at this point, but
- The back of the charge port door has some spiky plastic/resin parts (see picture below). Is that normal?
- The front of the truck sits about 1” closer to the tires then the back of the truck. (It’s the same height left to right, I know some people have had issues with that). I’ve seen this in kneel mode as well as standard height. I didn’t check other heights.
- I seem to get less range/efficiency then many people posting here. On a longish trip (>100 miles) going 65-70 on flat highway with no real wind in low suspension/all purpose with 21” wheel/tire combo at ~40 degrees I will get ~2.0 mi/kWh or ~250 miles of range. It’s worse if I’m on hilly terrain/go faster/anything else you would expect to cause it to be worse.
