AC became hot
irvineboy
Orange County
I sat in My vehicle for 2 hrs and noticed the AC became hot even though it was at 67 degrees F. Is this normal? I drove the vehicle for a few minutes and then the AC came back. The vehicle can’t be stationary for long periods of time to continuously use AC?
Also, the passenger side now can’t change the temperature. I only see option on drivers side to change temperature. Not sure what happened.
fromSf
m
Fremont, CA
Lexus Rx450H, 2023 Genesis GV60
I used to have the AC blowing hot air, and I wasn't able to drive when temperatures were hot. I also had a very poor charging experience. The service center fixed the issue by just flushing out the coolant and adding the proper amount of coolant. I believe an incorrect amount of coolant was the issue.
Yours may not be the same issue, just sharing my experience.
Oldsmobile_Mike
Manassas Park, VA
FG/FE R1T recv'd 3/31/2023
I build stuff
What was the ambient temperature? Was "auto" turned on? Imo not enough info to give accurate response.
If there is no passenger, the controls on that side become disabled.
240vPlug
ElectrifiedOutdoors.com
23 R1T (Limestone), 23 R1S (El Cap)
Was this in your BMW? 😁. The R1T had a FSA where the AC was overcharged and it caused it to work poorly. The remedy was to evacuate and recharge it.
HighVoltOverland
Laguna Beach
GW/OC R1T | Tesla MY | Jeep Wrangler TJ
Retired-ish
That's not normal behavior.
I use my truck as an office during summer as my unit doesn't have AC.
never had any issues like that sitting stationary in my garage/ on the street.
Campstream (company) made a device for piping AC to the bed of the truck (for tents)
The device wouldn't work if all units functioned like you are describing
majorfriend
Seth
Land Cruiser 100, Launch Edition R1T, Mustang Mach
IT Consultant
I had that happen a while back. I did a hard reboot and it never did it again
Kyle Connor also had something similar happen when picking up his R1T, hard reset fixed it.
irvineboy
Orange County
Rivian says I have to select the “Auto” button otherwise AC won’t turn on. Is that true?
I never selected this before and set the temperature to 65 and AC was cold. Not sure why I have to select “Auto” mode for AC to turn on. Is that what you guys do?
