Why do Rivians charge so slow?
mindstormsguy
Seattle area
Some
Everyone who is pointing out the gallons per minute fuel filling analogy is missing a key point. Batteries are not tanks of liquid. With gasoline, the pump at the station is basically what sets your refueling rate. That’s not how EVSE and battery technology works though. With batteries, all else being equal, the charge speed should be proportional to the size of the battery. It’s called “C rate”.
It’s common or standard for a battery (of basically any type) to charge at 1C. If a battery is 10Ah, then 1C = 10A, and charging would take 1 hour (or a little longer, because of tapering at the end). If a battery is 100Ah, then 1C = 100A, and charging takes… 1 hour!
So, if an EV is half as efficient as another, but it has a battery twice as large (to get the same range) it doesn’t matter. A battery twice the size should be able to charge twice as fast. Or put another way, if two EVs have the same charge rate in terms of C, then they’ll have the same charge time. Regardless of the size of the pack.
At the individual cell level, all there is is C. The cells don’t care how many volts and amps are delivered to the pack, they care how many C is delivered to them directly.
Unless an EV is maxing out at 1000V and 500A (the CCS limit), it’s not fair IMO to say “well, of course it charges slower, it’s a bigger battery”. The EVSE is not the limiting factor. Nor is the individual cell capability. The limiting factor is the design of the pack/vehicle itself. Either a cell selection that is simply not capable of the same type of individual charging curve, a more conservative design, a voltage limitation because the vehicle uses older transistor technology limiting to 400V, or a bad cooling system.
If you took two Rivian packs, wired them in series, and hooked them up to a single EA EVSE that is capable of 1000V (as most are) you’d add twice as many MPH. Why? Because you’d use the full voltage available from the EVSE, and you’d have twice as much cooling capacity.
Ziggy
Plainfield
Rivian r1s
I've road-tripped both the Tesla Model 3 performance (2020) and Rivian r1s (2023, 3300 miles, deliver 11/4/23). Working the bottom of the battery is harder due to reliability of the EA network, but when you do average time at each stop for Model 3 was 15-25 min (V3 superchargers, 250 KW max rate) vs. 25-40 min for the r1s (EA chargers max speed around 210-220 KW).
Once the Tesla network opens up for us we should be able to more aggressively work the bottom of the battery (arrive at 10% or less), but the time needed before leaving for the next charger will be inherently longer versus most other EVs. Its the price you pay to drive a car than can get you to Moab or similar and then do serious off-road adventuring.
Really need 350KW charging rates from 10-80% to make the time difference a moot point IMHO. Towing is really out of the question until 350+ KW rates and 200+ kWh batteries become the norm.
jjswan33
Joshua
Sandy, OR
Folks like you are missing the point that the efficiency of the vehicle matters when you are using miles added as a metric for charging speed. The study from Edmunds isn't looking at C it's looking at miles added per hour.
CrazyOne
At 75mph, the Hyundai has 100 miles less range than advertised. There may be a difference, but isn't nearly as big as it might seem. Others have raised several valid points. If cells are the same, increased charge rate per cell will cause more degradation.
mindstormsguy
Seattle area
Some
No, I’m not missing that point. Let me explain with two hypothetical EVs:
EV A: 300 mile range car, with a 5mile/kWh efficiency. This requires a 60kWh pack (300 / 5). Let’s say the cells can charge at 3C average. This would be 180kW (3 * 60). 180kW for a vehicle that does 5miles/kWh is 900miles/hour charging.
EV B: 300 mile range truck, with a 2.5mile/kWh efficiency. This requires a 120kWh pack (300 / 2.5). Let’s say the cells can charge at 3C average. This would be 360kW (3 * 120). 360kW for a vehicle that does 2.5miles/kWh is 900miles/hour charging.
For the same total range, and the same charging rate at the cell level in C, the miles added per hour is the same. The difference is only that the larger pack vehicle needs more kW (but this is only an EVSE limit if you get to 1000V * 500A = 500kW charging speeds), and that the larger pack will have a lot more load on a cooling system. But until we have trucks hitting 500kW for the entire charge session, there’s no reason that a truck needs to charge slower than a car even in terms of mph of charge added.
jjswan33
Joshua
Sandy, OR
I still say that the truck in your hypothetical example charges 2X faster then the car. This thread is literally the first time I have seen anyone use the metric C for charging speed, it might make sense for consumer electronics but when we are talking about 180kW sustained speeds vs 360kW sustained speeds then you are living in a future world because that is just not how EV charging works today.
That said if someone releases a truck that can charge a sustained 360kW charging speed then sign me up
momo3605
SF Bay Area
Lucid Air, 718 Spyder
I think the Rivian's charge cure is fantastic. Yes the miles/hr peak is low because the battery is huge and the vehicle is heavy/inefficient, BUT it charges at 200KW from 0 to past 50%. Majority of EVs are already at 100KW or less by 50%, even the 800V Lucid.
So yes, at the bottom of the pack where some cars peak at a very high 800-1000mph, sure, the Rivian is not great, but for the majority of the charge curve, the rivian is pulling double the kw compared to smaller cars with half the battery capacity.
mindstormsguy
Seattle area
Some
Yes, electrically speaking it would be twice as fast. I don’t really have interest in the language we use to compare two dissimilar vehicles though. I won’t argue semantics - that’s a losing argument for all involved. My point is simply that it’s not unreasonable (technology speaking) to expect a Rivian to add as many miles per hour of charging as any other vehicle.
mindstormsguy
Seattle area
Some
My 2019 etron pulls 150kW constantly all the way to 80%. And it’s a much smaller pack than the R1T (making it more impressive).
Rivian’s curve is mediocre.
momo3605
SF Bay Area
to be fair, the etron and taycan do have the fastest charging curves. But other than those, rivian is definitely top 5 for charging rate above 50%.
usulio
It is possible Audi is willing to stress and degrade the battery much more than Rivian.
mindstormsguy
Seattle area
Some
Rivian is certainly not bad. I really would like better performance above 50%, especially when towing. The F150 is no better though I don’t think.
I think Rivian’s biggest issue is thermals.
I’m hoping for great things for Rivian’s next gen. Time will tell.
shap
Austin,TX
BMW 45e, R1T
eTron is a really special case - they have a very expensive battery with a lot of cobalt that allows a constant charging rate till almost full. I do not know any other EV that does the same.
voxel
Nelson
Altamonte Springs, FL
Ioniq 5N, Mach-E 4X, 23 GC Limited
Yes... 2C charging.
Rivian is barely 1C charging most of the time.
