Warnings for front camera and sensors
lovelitlive2024
Illinois
Tesla Model Y
I just took delivery of a R1S last Friday and I started to get this issue this week. After I drive for a few mins, an error message saying the front camera is off would appear, and another error message saying the sensors are off would immediately pop up. Then I have the warning lights (right triangle with a exclamation mark, the forward collision warning, and lane departure warning) staying up on the dashboard for the next 10 minutes or so, then those warning lights would go away.
Is this happening to anyone else? I am guessing this is just a software issue.
BrianNakata
Sunriver, OR
2022 Rivian R1T, 2016 Shelby GT350
Retired Software Engineering Manager
I occasionally have the same warnings along with ride height not working. Leaving the vehicle alone and allowing it to sleep reset "fixes" the problems.
I agree it seems like software.
Oldsmobile_Mike
Manassas Park, VA
FG/FE R1T recv'd 3/31/2023
I build stuff
I would try doing an infotainment reset. And maybe also a full vehicle reset. Let us know if you need instructions for those (they've been covered a ton of times in forums and owner's manual). Also it probably wouldn't hurt to give the vehicle a good walk-around and make sure nothing obvious (physical damage to camera or sensors that could've occurred during shipping, for example). Could also be a loose wire. If it keeps occurring after the resets and sleep cycle, I'd probably call Rivian.
Good luck, let us know how it goes. ?
mpw81
'22 R1T
I had this issue start in December. Had it in for service in Jan. When I picked it up they said one of the wires was routed in a strange way and was rubbing up against something. They fixed it and I haven't had the issue since. I've also seen people having this attributed to a loose wiring harness, which would probably be similar. Also could be software related.
For context, the issue on my truck arose after 12k miles and ~16 months.
RBM3
Jon
eGolf, GX460
Erikbecker
Erik
Munich
Mechanical engineer
First, try rebooting the vehicle system – sometimes it's just a glitch that needs a quick reset. If the problem sticks around, it could be a software bug. Updating the software might do the trick. Also, check out the physical connections of the front camera and sensors. Make sure everything is snug and tight.
dmarsh
Darren
Parkland
2024 Rivian r1s
I just took delivery June 3 and have the same problem. In addition to the steering wheel shaking, I took it in to SC and they had the car for a week. Claimed it was a loose wire harness. BS, still have the same problem. Want me to go back to Miami, brutal commute, but I asked for a manager, this is crap, I want it flat bed into the shop, I am not wasting anymore time. Car has been there 3 times in 6 weeks.
JonBoyR1T
Randolph, NJ
2023 Rivian R1T
I have had the same issues shortly after getting my 23 R1T. I’m just living with it for now hoping it’s software but it happened on .11 and now on .19
James Kruse
Jim
Ca
Tesla/Rivian
Yes. My Rt1 gen2 has 900 miles on it. Same thing. Front senors are showing off. Soft reset no help
iamnid
Mercedes EQE, Rivian R1S
I've had the sensors go out on me which disables cruise control as well. A soft reset doesn't fix it but a hard reset does. I've also had the matrix headlights malfunction on me twice now which requires a hard reset to fix.
James Kruse
Jim
Ca
Tesla/Rivian
Hard reset does the trick for the sensors.
