Tire size, impact on towing???
C.R. Rivian
Charles
South Puget Sound
In the Tesla Model Y, towing capability is tied to tire choice: " Equip your Model Y with a high-strength steel tow bar and 2” hitch receiver capable of towing up to 3,500 pounds on 19” and 21” wheels or up to 2,300 pounds on 20” wheels. Tow Mode actively monitors trailer sway and adjusts wheel braking and speed".
Wondering if R1T will see any variance depending on tire/wheel choice.
Insights?
azbill
Bill
R1T, Mach E, Hummer EV SUT
Normally towing would only be affected by the tire load rating. Maybe Tesla has put thinner tires with lower rolling resistance on their 20" rims. Thinner tires would have a smaller load rating. Even though Tesla claims the X and Y are SUVs, they are not likely putting truck tires on them. Nor are they set up for any hard off roading.
Smithery
Model X owner chiming in.
Chose the 20" wheels.
(On the Model X) The overall tire diameter on the 22" is a *bit larger* than the 20"s, which negatively affects range.
The sidewall on the 22" is shorter, making it a harsher ride quality.
AFAIK, the load roading on the OEM 22" tires is the same as the load rating on the OEM 20" tires, even though the tow rating is 3,500lb vs 5,000lb.
I don't know if anyone has a definitive answer as to why, but I'm guessing the sidewall's negative effect on suspension characteristics is the reason.
We've towed right up at the 5000lb limit on our 20"s and it's a remarkable experience.
The Model X "trial run" of towing a heavy load and not even being able to tell is why I'm stoked about the R1T.
skyote
Austin, TX
The overall diameter on the 20s is a little over an inch taller than the 21s & 22s.
skyote
Austin, TX
Eeyore
Bruce
R1T LE, ID.4 Pro S, Honda Fit
Union Journeyman Electrician, foreman
