kwindrem
- First Name
- Kevin
- Joined
- Sep 5, 2026
- Threads
- 1
- Messages
- 1
- Reaction score
- 1
- Location
- California
- Vehicles
- none
- Thread starter
- #1
I am considering an R2 to tow a travel trailer. There is SO much information missing from Rivian documentation but what remains makes me think that towing with an R2 is almost a joke.
The 4,400 pound towing limit is documented and well understood.
Tongue weight is less so. Most SPECULATE that tongue weight is limited to 440 pounds. Nothing official from Rivian. Getting a single axle travel trailer down to that limit is extremely difficult. I have already switched to lithium batteries and moved them to the back of the trailer and removed one of the propane tanks. Cargo area is as empty as I can realistically make it. Best I can do is 480 pounds.
Lets assume for the moment that 480 pounds would be an acceptable tongue weight and consider additional situations.
The receive height above the ground is not specified. Multiple searches say it's on the order of 15 inches but nothing official. If that's accurate, I'd need about 4 inches of rise to tow level.
I found a note in the R2 manual that indicates the maximum rise is 1 inch (and 2 inch max drop). That rules out nearly all towing scenarios.
Horizontal clearance is also lacking. The manual specifies a maximum shank length of 8" which puts the trailer's tongue jack in line of the lift gate arc so it can't be raised when hitched. Yes, I've already turned the jack's head 90 degrees. Removing it entirely is a possibility with either the Jack-E-Up or replacing it with the Ultimate Trailer Jack.
There is also no information on the use of a weight distributing hitch. I've always used one to minimize squat.
Any information (not speculation) would be extremely helpful in making a rapid decision. Thanks.
