rogunenode
Nederland, CO
R1T Quad / Lotus Emira
TLDR version (via AI -- added by Admin)
Overall Verdict
The Rivian R2 handles general trails better than expected for its class, acting as a capable "soft-roader" or "normie" off-roader for camping trips or unpaved paths. However, it is fundamentally limited by its suspension design compared to heavier-duty off-roaders like the R1 series.
Where the R2 is Good for Off-Roading (Strengths)
  • Compact Size and Short Wheelbase: The vehicle's smaller physical footprint and short wheelbase are major assets on tight or winding trails, making it nimble and easy to maneuver around obstacles.
  • Trail Handling: It manages general, unpaved terrain and standard trail driving smoother and better than many typical crossovers in its class, easily surpassing basic daily drivers or standard EVs when heading toward a campsite or field.
Where the R2 is NOT Good for Off-Roading (Limitations)
  • Lack of Suspension Articulation: The most immediately noticeable drawback is its restricted suspension flex. Because it lacks an aggressive suspension travel range (and lacks features like a factory anti-roll bar disconnect in this context), the independent suspension setup limits downward reach.
  • Lifting Tires in Offset Ruts: Due to the limited articulation, when navigating uneven terrain or offset ruts, the R2 lifts a tire off the ground surprisingly easily.
  • Traction Struggles: When a tire gets lifted into the air because the suspension cannot reach down far enough, the vehicle can temporarily struggle to maintain forward momentum and traction until the electronic systems compensate.
Rad
Boulder, CO
2016 and 2004 MDX, 2016 Jeep JK
Thanks for sharing the video. I laughed at your comment: "I think I have more flexibility in my knees more than this thing does".
I'm surprised to see the low ground clearance and lack of articulation. A good opportunity for aftermarket enhancements.
rogunenode
rogunenode
Nederland, CO
It's not my video; just posting as a potential buyer interested in its off-road capability and figured I'm not the only one.
Hopefully, it won't be long before we see aftermarket options beyond spacer lifts.
macb00kemdanno
Brandon
Garner, NC
R2 LE Reservation, 2024 Tesla Model 3, 2023 Tesla Model Y
Considering that 95% of these will be commuters (just like the Model Y), finding their way to the local Starbucks, Whole Foods, Trader Joe's, REI, and school pickup line, it's more than fine.
For the other 5%, the R2 will easily clear the wooded trails and slightly rocky terrain that it will be subjected to. In other words, mission accomplished :D
rogunenode
rogunenode
Nederland, CO
You left out the small percentage of us who hoped for an R3X with more capability than wooded trails and slightly rocky terrain, aka, soft-roading. I get why Rivian hasn't done that (yet?). I recently drove a Macan GTS with air suspension and off-road mode. I'd wager it is on par with the R2's capabilities, but the R2 definitely has greater potential via mods.
a9967
Polestar 2, Hyundai Palisade
It also has chonky sway bars. Disconnecting those would help a bunch with articulation for offroad. Keeping in mind it's still an R2, not an R1.
Hopefully we see some quick disconnects hit the market.
Tom(myBoy)
SF East Bay
2015 Subaru Outback & 2015 eGolf
I watched that video last night on YouTube in part to introduce me to the R2’s off-road capability / limitations. And, in part to introduce me to more true off-roading.
I think there should be more comparisons between the R2 and midsize SUV competitor vehicles like the Jeeps, 4Runner, Bronco/Bronco Sport, Nissans & Hondas.
And, I too look forward to more aftermarket for adventuring with it.
scottf200
WNC
Past Ford Exped; curr TMX 100D; future BEV truck/SUV
sw engineer
You have missed the Out of Spec clip of it on the track. eg. blended use cases but leans toward people doing road driving (with corner handling, planted feel, etc)
"R2 may be the most fun EV I’ve ever driven "
Holler Wanderer
Nate
2023 Quad R1S, 2024 BMW i4 xDrive40
I don't think it would be fair to compare it to body on frame SUVs like the 4Runner and Jeeps.
Husky
Dave
New Hampshire
Genesis G70, Porsche 997.2, BMW E36 M3 sedan
Retired EE
We'll see if it's more fun to drive on the road than my EV6 😉
tivoboy
Paul
Palo Alto, CA
M3
Approach angle is the real take away deficiency.. but if one isn’t bouldering or trying to get up over large logs and stumps, that shouldn’t be TOO much of an issue. One only has to look at the front lower lip and relationship to the tire/ground to see that is going to be an issue.
It was probably done for a tiny bit more AERO, but at the sacrifice of approach angle.
And, as is always the case,
”good tires, but not great tires”
Rivian R1T R1S R2 Off-Road Ability Test Video -- Great Size, Limited Flex IMG_2546
TBH, it's expected of conventional independent suspension with sway bars. It's the sway bars that limit articulation. If the sway bar end links were replaced with ones with manual quick disconnects, more droop could be had. But, it with advanced traction control that knows to send power to the tire that does have traction (vs the one hanging in the air), it may not be necessary—and having two wheels in the air is not necessary end-of-story for forward progress.
R1 is also independent suspension front and rear. But it does not have sway bars. It had the dynamic hydraulic suspension dampers to simulate sway bars, by varying pressure within each damper. So it can droop more because of that, plus being a long travel design to begin with.
On a completely different topic... If these BFG all-weather tires had a R1-compatible size, it might actually be a decent jack-of-all-trades, master-of-none, alternative to the factory Goodyear's Territory AT. EDIT: And it does look like BFG has a XL 275/60R20 that has load and speed index of 116T, plus 3PMSF and 65k mileage warranty (and with white outlined lettering). $280/tire at TireRack. Very intriguing. @ksurfier, your thoughts?
