Will be curious to hear about water temperature after a long trip. My frunk bottom ends up getting pretty warm.
This is the only way? I guess I’m used to ordering online without having to interact with a person to make it happen.
Jeff mentions this in the video below. He is going to be testing it a bit next week if the weather in Portland cooperates. Ill be interested to see what he learns myself as 12 gallons of water is a fairly large thermal mass.Will be curious to hear about water temperature after a long trip. My frunk bottom ends up getting pretty warm.
Just to avoid any potential confusion--for people in general not just you--I designed the tank to replace the frunk shelf. By that I mean that anyone concerned that they can't store stuff on top of the tank like they would the frunk shelf, I would not be surprised if the tank can actually support more weight then the shelf. Jeff has a video of him loading camping gear on top of his W[=0===0=]TR without issue.Re: buying a second frunk floor panel and cutting openings for a cleaner look… if that was done (the cut outs), would the remainder of the tank be low enough for the floor panel to sit flat like OEM placement? Waiting for delivery of my water tank from BoxGods… AND my R1T Max.
We do have a water heater project in the works. Roof mounted with solar. You may have been thinking of that?For some reason I thought this would include a built in water heater as well. I guess I was confused?
Yeah, I was thinking about the in tank heater. Is that also still in the works? If so, how would it have power since the pump is already using the frunk outlet?We do have a water heater project in the works. Roof mounted with solar. You may have been thinking of that?
We have also discussed a tank heater for this tank and winter camping in our forums.
There are several ways to do it. You could leave the tank warmer plugged in to keep your tank from freezing, and when you need water swap to the pumps power cord. You could use a Y harness, etc.Yeah, I was thinking about the in tank heater. Is that also still in the works? If so, how would it have power since the pump is already using the frunk outlet?
Ah, thanks for clarification. So there's not really any way for me to have some mechanism to heat the water in there warm enough for a shower?There are several ways to do it. You could leave the tank warmer plugged in to keep your tank from freezing, and when you need water swap to the pumps power cord. You could use a Y harness, etc.
To be clear, a tank heater just provides enough heat to keep the water from freezing. It doesn't warm the water up enough to bathe in--there is a big difference in the amount of heat and energy required.
There are also lots of different styles / types of tank warmers. Stick on pads that fit on the bottom of the tank are the most common. Several of our group members are discussing different approaches they intend to try. To be candid, I live in South Texas--essentially sub tropics--so there isn't much I can contribute beyond making sure the tank was sized to leave enough for a quilted moving blanket for insulation.
And for doing the Funky Chicken!!! lolThanks to Seth and John for stopping what they were doing and taking the time to do this as it illustrates the point pretty clearly. These guys have been nothing but great!
None that I would want to be liable for recommending. It's a plastic tank designed to hold water. Not a water heater. You can certainly pump water from it to a device specifically designed to heat water, but you shouldn't heat water to bathing temperature inside the tank.Ah, thanks for clarification. So there's not really any way for me to have some mechanism to heat the water in there warm enough for a shower?
I’m patiently sitting by my window waiting for the UPS truck to arrive with mine today. The initial videos look great. I have no camping trips planned unfortunately, so probably going to resort to watering the plants in my driveway this weekend
