The key is consistency, i.e. go by the same tool/gauge as much as you can. Too many variables involved to influence measurement results. So reduce inconsistency by sticking with 1 constant. A few psi difference might irk your OCD tendencies, if you have it, but not going to make much difference in normal driving. Even while driving or parked (with partial exposure to sunlight) you will see the same or worse psi delta at each tire. In general, regardless of what car it is, always good to keep a good quality gauge, with release valve, so you have a consistent way to measure, verify or fine tune pressures to a ballpark equilibrium.
