Greg Chick
- First Name
- Greg
- Joined
- Jan 27, 2023
- Threads
- 7
- Messages
- 391
- Reaction score
- 266
- Location
- Tehachapi Ca. 93561
- Vehicles
- R1T
- Occupation
- Retired Plumbing Contractor
Ouch. My bet is alignment.
Ouch, are you driving in all purpose mode and standard ride height?I have had excessive tire wear of the rears on my quad, large, 22”.
Drive 99% on all purpose, low, moderate (formerly soft)
Alignment was done by Rivian Service when vehicle had 3000 miles on it. Now at 5800 miles rears are toast with the outside edges on both sides completely bald and the remaining tread at the markers (3/32). Any ideas as to why (other than misalignment) could have caused this excess wear?
All purpose, low ride height, moderate (previously soft), high regenOuch, are you driving in all purpose mode and standard ride height?
Almost certainly alignment. What's your cold tire pressure?I have had excessive tire wear of the rears on my quad, large, 22”.
Cold tire pressure is 48psiAlmost certainly alignment. What's your cold tire pressure?
My wear was even across the tire but I still burned through a set of OE Scorpion Zeros in just over 10k miles because there was WAY too much toe from the factory. Unfortunately, I didn't get an alignment until I replaced the tires (with Continental Terrain Contact HT instead of the stock Pirelli).
Either not done or incorrectly done, indeed. Without a printout of before/after it's impossible to know. I will say that Rivian's alignment specs allow for quite a bit of toe while still being within spec and a busy/lazy alignment tech may not adjust something that is marginally within spec even though it would result in considerably accelerated tire wear.Cold tire pressure is 48psi
It just does not make sense if the alignment was done 3000 miles ago and when I looked at my paperwork they measured the tread depth at 7/32” at that visit. No potholes, no curbs, no off-roading. If it truly is the alignment that is the culprit then 2 possibilities: it was never aligned when they said they did or it was done improperly.
2022 R1T, large pack, quad motor. Majority of miles is highway driving - only 2 stoplights in my county. Almost all driving is in all-purpose mode and no off road. I rotate the tires every 5000 miles.i thought it might be interesting to see how others OEM Pirelli tires, or other brand you've installed, are doing 20s, 21s or 22s. i have the 20s. below is my config, current mileage, number of rotations and tread depth. hoping this will give me data points on whether to get the Pirelli's again or switch.
Quad
Large pack
20" AT
95% drive in all-purpose mode, standard height
2 rotations (6000 miles)
current mileage: 13,500
tread depth = 10/32
