LukeNowland
Luke
2002 Mazda B2300
Field Technician
TLDR: Rivian said to expect 10%-80% in 27 minutes, and that’s about exactly what I saw.
Decided to test Rivians claims on the increased charging performance the other night. I was not technically able to precondition the pack, but I arrived at around 90 and outside temp was 70 so I don’t think it made a real difference.
Here is the curve data written out and deciphered.
Time/Rate/SoC
0:00 -000kw - 2%
2:00 - 213kw - 4%
5:00 - 215kw - 13%
7:00 - 216kw - 19%
8:00 - 217kw - 24%
10:00 - 221kw - 30%
11:00 - 203kw - 35%
13:00 - 213kw - 41%
15:00 - 176kw - 47%
16:00 - 161kw - 52%
18:00 - 142kw - 57%
19:00 - 129kw - 61%
21:00 - 107kw - 65%
22:00 - 99kw - 69%
24:00 - 94kw - 72%
26:00 - 88kw - 75%
27:00 - 80kw - 77%
29:00 - 76kw - 79%
30:00 - 72kw - 82%
32:00 - 71kw - 84%
34:00 - 63kw - 86%
35:00 - 61kw - 88%
37:00 - 60kw - 90%
38:00 - 57kw - 91%
40:00 - 57kw - 93%
C12farmer
2025 R1S
Thanks for posting this. I do think preconditioning forces the car to even out the pack temperature more than you can see.
Would be interested to see a charging curve from ABRP data. That gives a data point every 5-6 seconds.
10-60% still seems like the charging sweet spot, if you can make it to chargers within that use range.
Rade
Rade
US - Rhode Island
radmorningcoffee.blogspot.com
I am pleased with the upgrade! I have been using the DCFC, and plug in somewhere in the 30-40% range. Prior, it was a 45-50 minute session. Hit it the other morning and went from 38% to 85% in 35 minutes! Not even enough time to finish my Dunkin!
RoRoTheRivian
Rivian R1S Gen2
To clarify, this is the LFP battery? I didn't know they could reach 221 kw. I've yet to see that and remember reading it was maxed out lower than the non-LFP. Did you used to get 221 before? Or is it part of the update?
LukeNowland
Luke
2002 Mazda B2300
Field Technician
I noticed this too, however after some research, I think this is normal and its just extra kilowatts going into battery temp management and computers, not directly into the battery. Someone is more than welcome to correct me if I'm wrong.
Oldsmobile_Mike
Manassas Park, VA
FG/FE R1T recv'd 3/31/2023
I build stuff
Just curious since I didn't see it mentioned - was this at a Rivian charger, Tesla charger, or somewhere else?
C12farmer
2025 R1S
212kW is about the max that can go into the pack. I think 221kW is the output from the charger. There are losses and other consumption by the car.
