superfluid
Austin, TX
Rivian R1S, Kia Telluride
Tech and data
This is the third in a series of posts about how to improve how your Rivian’s audio system sounds. Find the other two here and here, both of which pertain to software versions older than 2024.27.01.
TLDR;
  1. Flatten your EQ by using the “Default” setting or the reset icon.
  2. Set 3D Surround Sound to Off.
  3. For stereo tracks, use these EQ settings: 63 Hz -2, 125 Hz -1, 250 Hz +1, 500 hZ -1, 1 kHz +/-0, 2 kHz +1, 4 kHz +1, 8 kHz +/-0, 16 kHz -3.
  4. For Dolby Atmos tracks, use these EQ settings: 63 Hz -1, 125 Hz 0, 250 Hz +1, 500 hZ -1, 1 kHz 0, 2 kHz 0, 4 kHz -1, 8 kHz 0, 16 kHz -3
  5. Use Tidal, Apple Music, or Spotify set to the highest streaming bitrate. Avoid Bluetooth for music playback.
  6. Start with your volume set to 9.
  7. Listen to a song you know well.
  8. Adjust EQ to taste.
If you make this change, let me know how you think it sounds.
Tip: Listen to the new setting for a while using familiar songs at low volume and higher-than-average volume. Your ears/brain may take a bit to get accustomed to the new balance. What should happen is that you hear instruments/sounds more clearly because overtly emphasized frequency ranges aren't drawing attention away from others. Then tweak to taste.
Rivian R1T R1S How to Improve a Gen 1 Rivian R1S’s Elevation Sound System After Update 2024.27.01 With Simple EQ Changes IMG_3169
The latest software update at the time of writing—2024.27.01—significantly changed the audio system. It added Apple Music and Audible apps, as well as Dolby Atmos immersive decoding for Gen 1 Meridian/Elevation and Gen 2 Premium systems. It also changed things about the audio system under the hood. This post pertains to the Gen 1 R1S with Elevation system, my vehicle.
Like many owners, I noticed output levels increased dramatically and my EQ settings were no longer appropriate after the update. I set about doing the same thing I did in this post’s sister posts: measure the system’s behavior, understand its implementation, and recommend improvements where applicable.
Objectives, Methodology, and Tests
Objectives
I ran tests to answer these questions:
  1. Did the update resolve the significant 20 dB imbalance between 450 Hz - 2 kHz that the previous version suffered from?
  2. Is the system louder after the 2024.27.01 update and is it a good thing?
  3. What EQ settings improve sound quality after the update?
  4. How did Rivian implement Atmos?
  5. How does the Gen 1 R1S Elevation 2024.27.01 sound compare with the Gen 1 R1S Meridian pre 2024.27.01?
Methodology
  • Flattened the EQ using the Default setting.
  • Turned off 3D Surround Sound and Dynamic Sound Adjustment.
  • Set Fade and Balance to default.
  • Turned off climate control to reduce in-cabin noise as much as possible.
  • Put a calibrated UMIK-1 microphone roughly where my ears would be in the driver’s seat.
  • Connected my MacBook Pro to the Rivian Audio system via Bluetooth. This connection method had meaningful downsides—namely data and resolution loss—but Rivian Support said they didn’t know another way to make the vehicle a target audio device. USB doesn’t work.
  • Set the Rivian’s volume to 9 to give me 75 dB of pink noise, C-weighted, generated by Room EQ Wizard (the industry standard acoustic measurement app). 75 dB is a standard level for taking measurements.
Rivian R1T R1S How to Improve a Gen 1 Rivian R1S’s Elevation Sound System After Update 2024.27.01 With Simple EQ Changes IMG_3164
Tests
I ran 5 sweeps from 0-20,000 Hz through the Bluetooth input to understand the system’s performance and set a baseline for improvements. A sweep is an audio signal sent to the sound system that sweeps across a given frequency range at a uniform volume. The recording microphone records the sound the speakers make and what the room—the cabin, in this case—does to change/distort the sound before it enters your ears. The closer the recording is to uniform, the more accurately the system will reproduce what is in the recording. But systems are never perfectly accurate because perfect accuracy requires a ridiculous set of physical conditions (anechoic chamber) that confuse the hell out of the brain and sounds terrible.
Speakers, amplifiers, and the cabin have physical characteristics and limitations that dramatically alter what we hear. Think of speaker and amplifier distortion as what your throat and lungs do when you try to sing Whitney Houston’s Higher Love. The average throat and lungs physically limit how accurately you can produce Whitney’s notes at her power levels; the louder we try to sing, the less control we have over our vocal cords, particularly at higher and lower octaves. Speakers have analogous limitations. That’s why good sound systems cost so much. A lot of engineering goes into making them hit higher output levels with low distortion.
Think of room/cabin distortion as what happens to the sound of your voice when you cup your hands around your mouth. It changes dramatically, generally not for the better.
Speakers, amplifiers, and the cabin effectively act as filters to the sound before it hits your ears. Any song you put through a system goes through the same filters. An audio engineer’s and acoustician’s job is to reduce the deleterious impact of those filters on your sound system while retaining their positive effects. Why some are positive is a much more complicated topic involving psychoacoustics, but suffice it to say that our brains rely on certain acoustic cues to understand the physical space we’re in and to ground our equilibriums. Take those away, and people can become dizzy and sick—not good while driving.
The adjustments we will make compensate for those distortions to help the sound we hear be as close to how it was recorded as we can manage. Since EQ is the only tool we have, and EQ only affects the relative loudness of certain frequency ranges, that’s what we’ll focus on improving: the relative loudness of certain frequency ranges.
Rivian R1T R1S How to Improve a Gen 1 Rivian R1S’s Elevation Sound System After Update 2024.27.01 With Simple EQ Changes IMG_3165
Results, Analysis, and Recommendations
We’ll answer each question one by one.
Q: Did the update resolve the significant 20 dB imbalance between 450 Hz - 2 kHz that the previous version suffered from?
A: Yes. The system no longer suffers from a severe imbalance between 450 Hz - 2 kHz where most vocal and acoustic instrument information lives.
This is the biggest takeaway of this update because it means two things:
  1. Rivian removed the Elevation system’s biggest performance shackle. Vocal and instrument clarity is hugely improved and we can use EQ to make improvements instead of compromised repairs. If you’re an Elevation owner, you’ll be thrilled.
  2. The 450 Hz - 2 kHz imbalance was created by software, not by a physical crossover like I previously thought. A physical crossover can’t be changed by a software update. The sound system is more adjustable than I believed, which means more improvements are possible in the future. How about implementing a parametric EQ or offering Dirac Live room correction as a paid upgrade, Rivian?
Here is the reference measurement with Default (flat) EQ showing that the 450 Hz - 2 kHz issue is gone. I also highlighted new problem areas, none of which are severe.
Rivian R1T R1S How to Improve a Gen 1 Rivian R1S’s Elevation Sound System After Update 2024.27.01 With Simple EQ Changes Gen 1 R1S Elevation 2024.27.01 Default EQ - Response Curve
Compare that to the reference sweep of the Gen 1 R1S Elevation system prior to 2024.27.01.
Rivian R1T R1S How to Improve a Gen 1 Rivian R1S’s Elevation Sound System After Update 2024.27.01 With Simple EQ Changes Gen 1 R1S Elevation Pre-2024.27.01 Default EQ - Response Curve
If you recall from my pre-2024.27.01 analysis, the 20 dB imbalance of the Elevation system between 450 Hz and 2 kHz was a major problem because the Rivian’s graphic EQ limited us to changing level at 1 kHz, smack in the middle of the problem area. It only allowed us to reduce the 600 Hz peak at the cost of dropping 1 - 2 kHz lower than it already was, the critical frequency range for the human voice and many acoustic instruments. The best we could do was strike a balance between cutting the 600 Hz hump enough to reduce the mud around voices and instruments and reducing the detail of voices and instruments within 1 - 2 kHz. It was a major compromise.
But with 2024.27.01, that problem is gone. Now, we can use EQ to make meaningful improvements to vocal and instrument clarity.
Q: Is the system louder after the 2024.27.01 update and is it a good thing?
A: The 2024.27.01 increased the overall output level of the system by a lot. I think it’s a good thing.
The previous software required a volume setting of 16 to reach 75 dB of C-weighted pink noise. 2024.27.01 needed a volume setting of 9 to reach the same volume. Because I can’t A/B the new and previous software, I can’t measure how many dB louder the new software is at the same volume setting. But if we assume the volume scale is linear (it probably isn’t based on other owners’ reports that volume 2 is a lot louder than volume 1), then the new software is 44% louder than the old one.
If you want an idea of why this change is good, read on. If not, skip this section; it’s long.
Many owners complained that their Rivian systems were weak, lacking “punch” and “tightness,” and needing a volume setting between 16-22 to reach acceptable listening levels. Some owners noted that the system used to sound punchy but a subsequent update castrated it. I believe Rivian tried to address those complaints with the volume change. I don’t know why they didn’t mention it in their release notes except that they might have considered it a bug to be swept under the rug. It’s a shame because it’s an important change.
As we established by measurement, the updated system requires a lower volume level (9 vs. 16) to hit the same sound pressure level (75 dB) without a hardware change. That means the change was digital. It’s hard to know exactly how they made the change because integrated car systems are complex and abstracted, but here’s how I think they did it and why it matters to sound quality.
The most likely thing they did was increase the output level of the DAC (digital-to-analog converter). A DAC converts the digital output (bits and bytes) of the streaming player into a low-level, voltage-modulated analog signal that is then further amplified by power amplifiers that power the speakers. Power amplifiers multiply the incoming signal to levels that can move speaker cones at listening volumes. The volume setting we control on the dash changes how much the amplifiers raise that signal. Boosting the DAC’s output means the amplifier amplifies a higher-level input signal, resulting in higher output for the same volume setting, all else equal.
Cool, but why does boosting the DAC’s output matter for sound quality?
High and low output signals differ in more ways than simply their number of volts. The main difference—for the question of loudness and punchiness—is their signal-to-noise ratios (SNR). High SNR is better than low SNR.
Every electrical component introduces noise into a signal. No electrical circuit is free from electromagnetic interference (EMI) or inductance, capacitance, or thermal problems. Electricity’s behavior in circuits is maddeningly non-linear, making noise difficult to prevent and eliminate. The more electrical power we put through a circuit, the bigger the noise problems become. I’m not an electrical engineer, but any EE would confirm that. To any EE out there, please add any details/clarifications/corrections to what I’m about to explain.
Each time an electrical component touches an incoming signal (i.e., the music), the component adds noise. To help you auralize noise, think of it as a hiss and/or hum. You might have put your ear up to your parents’ old Cerwin Vega system and heard a quiet hiss when nothing was playing. That’s noise. In fact, we call that the “noise floor” because it’s there whether we’re playing something or not. We just don’t usually perceive it when playing something loudly enough to mask it.
The problem is that amplifiers and speakers perceive it. They don’t differentiate between signal and noise. It’s all signal to them; volts are volts. Since every analog signal contains noise, amplifying that signal amplifies its noise right along with it. This brings us back to the DAC’s output level and the system update.
If the DAC outputs a low-level signal compared to its noise floor (i.e., low SNR), then the amplification stage will pick all of that up and boost both the signal and the noise by the same amount. If, for the sake of illustration, the DAC outputs 50% signal and 50% noise (an SNR of 1:1), and the amplifier multiplies the power by 100x to drive the speakers, 50% of the sound the speakers produce will be noise.
Remember cassette tape? Ever recorded someone whispering on a cassette? When you played it back, the hiss was almost as loud as the voice, maybe louder. Imagine playing that through your 1,200-watt car system.
Noise destroys sound quality in three main ways:
  1. Noise masks the music. It’s like trying to talk to someone while using a blow dryer; you can’t understand anything they’re saying. They can keep yelling louder but if the blow dryer keeps getting louder with them, more energy is wasted and nothing improves.
  2. The amplifier spends power reproducing noise. An amplifier can only produce so much power before it starts to distort audibly. If it spends more energy amplifying noise, it spends less energy reproducing music, especially parts that require high power like deep bass notes and snare hits.
  3. The speaker reproduces the noise, which increases how much the speaker distorts the music. A speaker is basically a magnet that moves a cone using electricity. That magnet has to accelerate, stop, and return the cone rapidly. A pure 10 kHz signal makes the cone oscillate 10,000 times per second. Noise, which comprises many frequencies, makes the magnet and cone work even harder. The more noise the speaker has to reproduce, the harder it has to work and the more mistakes it will make as it tries to reproduce the music.
All these reasons add up to sound that is weak and empty, just like a homemade cassette recording.
We want a high SNR. If the DAC outputs 95% signal and 5% noise, then the noise is inaudible, the amplifier spends more energy on reproducing the bass and treble of the music, and the speakers distort less. The system sounds punchier and more dynamic because it is. Because the Rivian system sounds a lot punchier and more dynamic, and they fixed the 450 Hz - 2 kHz frequency issue digitally, I think Rivian increased the DAC’s output and lowered its SNR with the update. I don’t have a way to verify this without taking panels off and performing tests along the signal chain, but that’s the best theory I have for those interested enough to have read this far =)
Q: What EQ settings improve sound quality after the update?
A: For stereo tracks: 63 Hz -2, 125 Hz -1, 250 Hz +1, 500 hZ -1, 1 kHz 0, 2 kHz +1, 4 kHz +1, 8 kHz 0, 16 kHz -3
Listening Tests
TIDAL on Master quality, 3D Surround Sound set to Off, Dynamic Sound Adjustment set to Off, and volume 14.
Flat EQ
Two things were immediately apparent:
  1. The system was a lot louder, punchier, and less distorted than before. See the above explanation of why.
  2. The sound was much more neutral than before, absent issues that made me grimace. See the above explanation of why.
I wasn’t surprised by the loudness. I was surprised by the neutrality.
Whatever Rivian did, it improved the system significantly.
Listening to Send My Love by Adele, vocal clarity was listenable out of the box—especially consonant articulation—which was not true of the previous update. Reverb tails were more detailed, but also overly bright. Bass was tighter and less bloated, though still boosted more than I’d consider necessary. Mids were certainly recessed, reducing vocal prominence and the acoustic guitar’s body. Sound staging remained narrow, imaging weak. But staging and imaging weren’t new issues, just ones I didn’t pay much attention to prior to the update because I had bigger issues to worry about.
Listening to Lost Cause by Billie Eilish, vocal clarity remained reasonably good. Bass was solid and deep. The overall system has a ton more headroom than before: I could crank the volume to uncomfortable levels without bothersome distortion. Nice. Imaging was an even bigger mess than with Send My Love because Lost Cause’s phasing/chorus effects highlighted timing disparities between L and R speakers at the driver’s listening position—but it wasn’t noticeably different from pre-update. It was probably just more noticeable now that other issues were absent.
To my ears, this is the best the Gen 1 R1S Elevation system at default has sounded to date. The measurements back that up.
Let’s see how we can improve it with EQ. Here's the same graph you saw earlier.
EQ Adjustment #1
2 kHz +2, 4 kHz -1, 8 kHz -2, 16 kHz -6
The first thing I noticed was a general lack of vocal clarity and too much sibilance and harshness in crash cymbals and high hats. As I turned the volume up to better hear vocals, the harshness bit hard. I toned down the harshness and leveled out the vocals with the following adjustments.
Lost Cause - Measures closer to “flat” but sounds muffled and lacking in detail, particularly guitar strick plucks and vocal sibilants. Midrange vocals were more balanced, but they lost detail and air. Low-mids were a bit muddy, bloated, masking some vocal information.
Most of the songs I listened to sounded like that. I did a second round of adjustments to see if I could do better.
EQ Adjustment #2
Cutting 16 kHz -3 was better than -6. -6 eliminated too much detail. 16 kHz could be adjusted to taste between -3 and -5 depending on how loud one likes to listen. Returning 8 kHz to 0 brought back some cymbal and string definition.
Cutting 500 Hz by -2 helped with the mud but felt a little hollow. -1 was better, though not great.
Change on the Rise by Avi Kaplan - Vocals were less weighty and chesty than they should be. Adding 250 Hz +2 helped return weight to his voice.
Cutting 63 hz -2 and 125 Hz -1 helped clean up ringing bass notes and sharpened bass note definition, particularly acoustic bass.
To my ears, these settings created the best balance of bass depth, bass definition, and vocal and instrumental clarity and detail. YMMV.
Here’s what the response curve looks like after these adjustments. Because each adjustment was small, there wasn’t much to highlight other than to say it’s more balanced overall. Your ears should hear that.
Rivian R1T R1S How to Improve a Gen 1 Rivian R1S’s Elevation Sound System After Update 2024.27.01 With Simple EQ Changes Gen 1 R1S Elevation 2024.27.01 EQ 2 - Response Curve
A Note About Stereo Imaging
You can’t get “stereo imaging” in a car unless you sit in the middle, equidistant between the left and right speakers. Stereo imaging is an illusion created by the same signal emerging from the left and right speakers and reaching your ears at the same time with the same volume. Sound from the left and right speakers in a car do not reach the driver’s ears at the same time or with the same volume because the driver is sitting much closer to the left speaker than the right one.
You can test this for yourself by playing a song and moving your head over the center console. The stereo image appears quite clearly in that position.
You can’t use Fade or Balance to fix the stereo image because they simply reduce the volume of certain speakers. They do nothing about timing. Without having done thorough testing, I believe Fade/Balance mixes channels together as you move it around. If you fade hard left, it mixes 100% of the left and right channels and puts them into the left speaker. This makes Fade/Balance even less useful for fixing stereo imaging problems because the sound that should be lowered in one channel now comes out of another.
Rivian R1T R1S How to Improve a Gen 1 Rivian R1S’s Elevation Sound System After Update 2024.27.01 With Simple EQ Changes IMG_3170
Q: How well did Rivian implement Atmos?
A: Pretty well--with caveats.
Even though I love what Atmos can do for music, I don’t listen to Atmos music much; most of my favorite music isn’t available in Atmos. I did cursory tests of the Atmos implementation to fact-find and gather first impressions.
I was surprised by how good Atmos tracks sounded in my Rivian. Bad Guy and Lost Cause by Billie Eilish in Atmos sounded much more open and enveloping than their stereo counterparts. That said, with the Default EQ, songs were definitely juiced and not neutral. Highs, particularly sibilants and cymbals, were overly emphasized. Bass was controlled, if slightly anemic compared to all of the mid and high information. But the implementation was pretty good. Overheads weren’t distracting except the occassional buzzing in the overhead left speaker. I suspect that was a residual bug from a previously known issue. The separate center channel definitely anchored vocals and snares to the center, clarifying the soundstage considerably.
I made some quick adjustments to balance the frequency response by restoring some bass and toning down the critical vocal range but didn’t do any objective measurements.
I suspect Atmos required a bit less bass cutting because Atmos is mastered at a lower level (-18 DBFS) than stereo mixes. I suspect the 2 - 4 kHz bands were hotter in Atmos mixes because they engage the center channel where most vocal information is mixed, adding energy to that range.
I listened to a few more tracks to better understand how Rivian’s implementation positions sound objects around the cabin.
Yeah! by User - It was interesting to hear backup vocals coming from behind my listening positioning and Usher’s main vocals coming from in front. The chorus also comes from behind with the sharp synth lead line mixed way too high, standing out and breaking immersion. Some vocal elements nearly disappeared as they got mixed into the back channels. Either the mix was incoherent and disjointed or the way Rivian rendered Atmos was screwy. I’m not sure who mixed this to Atmos but they made strange decisions.
BOOM by Tiesto - This is a standard track for testing immersive sound mixes. The Rivian renders it strangely. The main synth and vocal verse were sent to the back of the vehicle. I’ll have to do some more comparisons to how it was mixed for a home theater, but it doesn’t sound good.
Note: While the update touted Apple Music + Spatial Audio, TIDAL also decodes Atmos. When you playback an Atmos track with TIDAL, it doesn’t display a badge that it’s decoding Dolby Atmos, but it is. You can test this by searching TIDAL for “billie eillish atmos” and playing any of the songs on that playlist.
The 3D Surround Sound On setting appears to have no effect on stereo or Atmos sources. That seems like a bug or a vestige of Atmos implementation. The Enhanced setting seems to send some information to second-row height speakers to act as side surround speakers. The effect is overemphasized and reduces your ability to localize sound that should be coming from directly ahead (i.e. vocals). I don’t care for it.
Q: How does the Gen 1 R1S Elevation 2024.27.01 sound compare with the Gen 1 R1S Meridian pre 2024.27.01?
A: Quite well.
Like many folks, I ordered my Rivian with the upgraded package to get the Meridian system. When Rivian swapped it for the Elevation system before delivery, I was quite upset. When they said people preferred the Elevation over the Meridian, I became distrustful. When I measured my R1S Elevation and compared it to @RivianBowerbird 's R1T Meridian, my suspicions were confirmed: the Elevation was inferior to the Meridian objectively and perceptually. I believed the disparity was hardware-based and unchangeable. I gave up hope of having a sound system in my R1S that I enjoyed.
2024.27.01 changed that. It brought my R1S’s frequency response back in line with what I’d expect from a properly tuned system and got it close to the Meridian’s response. Here it is compared to @skyote ’s Gen 1 R1S Meridian before he updated to 2024.27.01. It’s far more similar than it was.
I’m enjoying my sound system for the first time and don’t mind that it’s not a Meridian.
Thanks, Rivian.
Rivian R1T R1S How to Improve a Gen 1 Rivian R1S’s Elevation Sound System After Update 2024.27.01 With Simple EQ Changes Gen 1 R1S Elevation 2024.27.01 vs. Meridian Pre-2024.27.01 Default EQ - Response Curve
If you found this post beneficial, please consider buying me a cup of sake. I'd appreciate it. Kanpai!
Rivian R1T R1S How to Improve a Gen 1 Rivian R1S’s Elevation Sound System After Update 2024.27.01 With Simple EQ Changes Xnip2024-08-28_12-22-22
Rub-ish
B
Las Vegas
2023 R1S, 2022 Volvo XC60 T8 ER, 2006 Audi A3
Sound Engineer
Greatly appreciate the leg work and care...I had just defaulted to Flat and was happy enough!
The make up "gain" to drive the components really did bring the system to a respectable point. (surprising that the guts were always in there)
As a full time audio engineer...people would ask my biggest complaint about the Rivian and it pained me to respond that I was boxed in to this mediocre listening experience!
I'm really looking forward to implementing and fiddling with your suggested changes!
Also dreading that all of this was some unintended consequence and it all gets nerfed sometime in the future.
Really hoping we get a full parametric/graphic EQ and some custom save slots in future updates.
Would be incredible if Dirac could be implemented post build via software as well!
Again THANK YOU!!!
R1SFamilyGuy
NJ
Mazda CX-5
I do software things
I only read the TL;DR but the amount of detail in your post…wow ?:clap:
superfluid
superfluid
Austin, TX
Tech and data
Again THANK YOU!!!
I was surprised, too. A parametric EQ with frequency and Q adjustments would be really level up the system. Multiple custom EQ slots would too, especially now that we have Atmos.
Let me know what you think about the suggestions!
s0ysauce
Appreciate the time and effort you put into measuring the differences the update made. It's too bad there are a lot of variances in Atmos recordings and remixes. I agree, a lot of my favorite music isn't remastered in Atmos so this update was bittersweet.
PhatDaddy
Jim
Coastal Central Florida
2025 G2 R1T El Cap PDM; (RIP: 2024 G1 R1T RC PDM)
Retired IT
As a ‘detail guy’, I am beyond impressed with your attention to detail.
WAY over my head, but really appreciate the work and adopted your recommendations.
BTW, I performed no less than 4 infotainment resets after the update and still had the entire left (or was it right?) stereo track virtually vacant which made every song via Apple Music really awful (once I figured out what was going on), while music via iPhone BT was fine. Missing stereo channel has been reported elsewhere in the forums since the update, with some indications that maybe it comes and goes after receiving phone calls or interactions with Alexa.
The only thing that resolved the issues for me (and gave me the wildly touted ‘new Apple Music positives’, including volume boost) was a total vehicle (hazard flasher switch) reset. Hope the results stick!
ravian
Debarshi
RavianPwd5
Model S, Sienna
I’m surprised that rivian does not tweak their factory system to sound flat at a flat eq setting.
i had carried out a similar test on my Tesla (using Rew, umik1) back in 2017 and the response was darn flat.
HaveBlue
I simply gave up, put the fader slider to the middle of the back seats and turned on 3d to use all the speakers
superfluid
superfluid
Austin, TX
Tech and data
Thanks a ton for this. You should set up a Buy Me A Coffee—I’d gladly throw you some cash for your time and effort here. Highly appreciate your methodology.
That is great idea and really generous of you. Will do.
