wheel size for spare
steve102
steve
Florida
rivian r1s
retired physician
Can a 21 inch wheel be used as a temporary wheel on a rivian with 22 inch wheels? I have a r1s with 21 inch wheels and a family member has the 22 inch wheels. I would like to purchase a 21 inch spare for use in both cars if needed. Thanks for your response.
It's not so much the wheel that matters. It's the overall diameter of the tires. Between 275/55R21 and 275/50R22 there is a -0.3% difference (or a tenth of an inch in diameter). Driven temporarily and conservatively, that might not be enough to upset stability and traction control software. But I don't know for sure. Personally, I would match with the rest so that you can rotate them—as a part of your 7,500 mi maintenance interval—and get more use out of tires before replacement is needed. Assuming tread depth isn't too different (more than 2/32") between all 5 tires. Shouldn't have any problems finding individual wheels in each size on eBay or from salvagers.
R1Thor
Joe
Lancaster, PA
Mechanical Engineering Lead
Keep in mind the inflate-a-spare for the R1S is all of 30" inflated. So long as you're truly using it temporarily (low miles, low speed), you should be fine with some disparity.
babock
Bruce
Los Angeles and South Lake Tahoe
2025 Rivian R1T, 2024 GMC Denali 2500HD, 2022 Hyundai SantaFe PHEV
Retired Electrical Engineer
I bought a 21" spare for my 22" R1T...it's a spare until get the tire fixed/replace so I don't see an issue.
No different than using the space saver spare that the R1S uses
HaveBlue
Won't be a problem but storing it is an issue on the R1S. The space saver is a 20
