Treadwright tires?
joelster
joelster
Joel
PDX
I'm not here to defend their technology but there is info on their website if anybody is interested. These are a bead to bead re-mold. They are not attaching a pre-formed tread or cap to the tire as you would in a re-tread. While yes, they are putting new tread onto tires, it is simply not apples to apples with retreads.
TollKeeper
Brighton, CO
Ast HR Director
Not entirely true... Large truck tires are recapped thru the same process, to a point.
The difference.
Large truck tires, and recaps of old, are ground down, and then a new layer of ruber is laid down, then a split tire tread case is laid over, stapled together at the ends, then put into a vulcanization oven to cure and bond.
Treadwright applies new rubber down to a tread depth + estimated pressing. Then places the tire into a vulcanization press, to embed the new tread pattern, and to bond the layered materials.
I will grant you its a better process than the old way..
However, you are still dealing with a unknown case, that may have been run low/hot, high, offroad, and other unknown variables. This is why when I did the process, I sent them my own cases to use, as they never had a puncture, never been ran low, etc.
I used the tired I had for 8000 miles.. Had my tires rebalanced 13 times, and rotated 3 times. Was never able to get rid of the vibration, or whatever issue it was. I sold them to a guy for his trailered off-roader.
Next tire was a new set of Michelin Defender LTX M/S, have not had an issue since. Still have that truck, still running those tires, although now on my 3rd set of them. Truck, a 2004 GMC Envoy, now has over 370k miles, of which I have put on 280k myself.
joelster
joelster
Joel
PDX
The difference.
Good feedback. Thanks.
