Not really when the underlying vehicle is already over 7k lbs. A gross weight change of 10% only impacts consumption by about 4%. Cargo (without aero penalty) is close to irrelevant to range/efficiency in EV truck world. Better to have a low profile 500lb cast iron roof box than a tall one made of platinum weighing only a few pounds.I expected this result. Once you're moving (assuming same for same air resistance), it shouldn't affect range/efficiency much.
However, in constant stop and go, I'm sure it would play a role. That initial force needed to move that much mass is not insignificant.
As one of the guys mentioned driving uphill probably makes the biggest difference. If R1T is towing a magical RV with zero rolling resistance and zero drag that weighs 10,000 Lb, it should lose 6.53 KWh every 1000 feet elevation gained in addition to 2KWh/mi (and RV friction losses). That kinda sounds low, It has been a few decades since my school days. Someone check my math:Not really when the underlying vehicle is already over 7k lbs. A gross weight change of 10% only impacts consumption by about 4%. Cargo (without aero penalty) is close to irrelevant to range/efficiency in EV truck world. Better to have a low profile 500lb cast iron roof box than a tall one made of platinum weighing only a few pounds.
It's like asking the elephant if they feel the toddler on their back.
Well yes, when you go to 10,000 lbs of additional weight it starts to make a real impact. My point was adding cargo type weight, particularly in the cab or bed that doesn't have any friction or aero penalties as well, will have an impact that is less than half of the percent of total weight added. So, for something like Kyle's test, if you could get full payload capacity inside the cabin, it would still only slightly impact your range.As one of the guys mentioned driving uphill probably makes the biggest difference. If R1T is towing a magical RV with zero rolling resistance and zero drag that weighs 10,000 Lb, it should lose 6.53 KWh every 1000 feet elevation gained in addition to 2KWh/mi (and RV friction losses). That kinda sounds low, It has been a few decades since my school days. Someone check my math:
It takes 10 Nm to raise 1 Kg to 1 meter so it should take 23503128 Nm (6.53 KWh) to raise 17,000 lb to 1000 ft. Is that right?
Thanks for summarizing. It answers what I figured, that aerodynamics are more important, which I suspect is the same with any load or trailer.Not much new here. If you want the gist of it, aero is still the main factor. 2 mi/KWh loaded to the max on 22s at 73 mile per hour speed. Basically negligible impact due to load.
These people are fun to watch thoughNot much new here. If you want the gist of it, aero is still the main factor. 2 mi/KWh loaded to the max on 22s at 73 mile per hour speed. Basically negligible impact due to load.
