Meridian vs. standard sound system
Davethadog
YaMa
Trucks, bikes, excavators
I've said it before and I'll say it again. Just give me the nice seats and then charge me $5000 for a set of line outs and I will take it from there with better results. I wish OEMs didn't make it such a nightmare to squeeze good sound out of "high end" systems.
ironpig
Los Angeles, CA
With the giant Tesla inspired home screens and dash design in EVs and other new cars I think these days are almost entirely over.
It's such a bummer. I used to love upgrading the stereo and speakers in my cars. It was one of the great joys of car ownership.
shamoo
Rivian R1S, Porsche 911 GT3
Cybersecurity
You can use any basic sound processor/LCI/DAC type device to do exactly that. Most cars now have a lot of integration with Infotainment.
I've used $99 AudioControl LCIs to multi-thousand dollar processors and the quality is very similar. To the average person, they will be blown away with the $99 model, channeling music to an amplifier and then to speakers/subs.
Blueassassin
Allen
il
Equipment Manager
hmm I wonder if i could fit two solo 12's in the gear tunnel. open the passthrough to act as a port almost. ?
Davethadog
YaMa
Im aware that it's easy to get line level out from amplifiers. But it's not often easy to do the rest of the integration. Output for things like proximity beepers, phone calls have different signals at different gains and it can be a huge headache to get everything to play nice. Hell, the sensitivity for speed sensitive volume was actually a signal embedded in the sub out channel from my head unit to my amplifier in my 2019 Ram 1500. If not for a custom set of firmware on my DSR1 I wouldn't be able to process that at all.
Not saying it can't be done, but its annoying and I hate it and I'm old and I'm just here to bitch.
No.92
Jeep Wrangler
For those who are considering the higher model trim for $5K more ONLY for the sound system, I would recommend against it.
You will find aftermarket options much cheaper and if you were willing to spend $5K, it'll blow your mind what the aftermarket can provide.
Even in these times where there is so much integration with factory audio, there are ways to separate out the audio into sound processors and amplifiers and then to speakers. There's no concern that your factory systems like climate control, maps, and even audio controls on the screen will be affected. Of course I'm generalizing and not all vehicles are the same, but rest assured a good aftermarket audio person can do wonders.
Would you trust an installer to install an aftermarket sound system in the R1T? How would you connect to the main screen? How would they disassemble the dashboard AND put it back in one piece without the permanent rattle? I sure as hell wouldn't trust some guy at Best Buy to do it and I've had installs at Best Buy
shamoo
Cybersecurity
Well that's the beauty of these types of solutions. Nothing to do with the main screen. Once someone figures out the wiring of the Rivian (I'm sure it'll happen soon, as aftermarket companies are probably itching to get their hands on them to create new products), it'll be easy to see where the audio output wires/cabling are. The sound processor/DAC/LCI takes that and outputs "clean" audio to an amplifier. It is often under the middle console/armrest area where the speaker wiring runs to the back of the vehicle (or maybe on the side sills).
That way everything else is untouched. Maybe some CANBUS type issues or something. Not claiming it will be easy since every vehicle is different but it isn't as difficult as most people think.
And no, you don't go to Best Buy. You would go to a reputable high end car audio installer. :)
E.S.
Florida
Chevy Bolt
Ah, maybe I'm behind the times. I also don't know the exact placement of the factory sub and how it may play out and/or if replacing it with another in the same location would work (i.e.: if there's enough air flow, etc).
Honestly, it depends on the company doing it. I've seen some rather impressive works back in the day. I recall a company that did a custom 7" specially designed small enclosure with a 50 watt amp to power it for Mazda Miata. I was floored when I heard how crisp and smooth that base was. IIRC it was rated to pump out 32 - 150hz, but it was PHENOMENAL! Sadly, a lot of these small companies got ran over (and didn't survive) by larger named brands (like Bose, Meridian, etc) that worked with vehicle manufacturers to make high quality OEM systems. I agree wholeheartedly with what you stated above - do NOT go to Best buy or similar stores to get your audio system upgraded. They're the pits
No.92
Jeep Wrangler
Sure but even a "reputable" installer would not have installed on an R1T (most likely) and having he/she take the panels/dash out? I would never trust anyone to put things back together properly without any rattling or loss of a clip here and there. It's never going to be the same as factory. And FWIW, the Meridian sounds amazing. Every part of the soundscape is isolated (treble, mid, bass) and the sub is tight and not boomy. It sounds amazing even with Spotify. I am not easily impressed as well as I consider myself an audiophile having spent over $10K just on my home audio/theater setup
shamoo
Cybersecurity
I suppose it would be the same as any car right? If I did intend to modify my R1S sound system (99% do not intend to), I would make sure there was enough information out there and plenty of guinea pigs before me. Plus I'm sure aftermarket companies will be itching to get their hands on one to learn.
Speedrye
NC
Commodore, Supra, FJ Cruiser
There's always wasted space in a vehicle that can be used for upgraded audio! I prefer a stealth look without losing any functional space, so it gets more challenging. I'm expecting to be happy with the Meridian system overall, but it won't have enough bass (or deep enough bass) for me, so I'll likely look at adding/replacing the sub at a minimum. I'm fine cutting up a new vehicle a bit if needed, so long as the install looks clean and appropriate for a $100k+ vehicle.
No.92
Jeep Wrangler
I've had subs installed in previous vehicles and yes you can get LOTS of bass in an aftermarket setup, but the Meridian comes with very nice punchy bass. The bass, IMO, is a perfect balance with mids and treble. Just enough punch to sound great with all songs (and trust me, I love bass), but not enough to tell all your neighbors in the next neighborhood that you're listening to music.
Speedrye
NC
My bigger concern is the frequency. A lot of my music is below 30hz where smaller subwoofers just don't work and I feel the music is lacking as a result.
frostbit3
Texas Coast
2022 Rivian R1T
The other thing to keep in mind is your ability to get audio to the Meridian sound system. If you're like me and are not a Spotify subscriber, than my understanding as of this writing is your only option is bluetooth which will degrade the quality of the audio being played. I haven't read anything about Rivian supporting (or officially not supporting for that matter) music over USB so that's another variable.
I think they also support Amazon music, but I thought that also required the Alexa app on your phone but I'm not positive on that one either.
