prasadtakkar
- First Name
- Prasad
- Joined
- Aug 12, 2020
- Threads
- 5
- Messages
- 84
- Reaction score
- 86
- Location
- Dublin, California
- Vehicles
- Tesla Model Y LR, Rivian R1S LE
- Thread starter
- #1
On a vehicle like Aptera, it could be enormously helpful since they depend on skin cooling for the battery.Itās an interesting idea, but there are so many factors I am skeptical of how well this would work in practice. If itās 90+ degrees outside and humid I doubt the cold air would make it very far under the truck to help with battery tempā¦
True. Unfortunately weāll never know for sure because Aptera is the Canoo of fuselage shaped EVs.On a vehicle like Aptera, it could be enormously helpful since they depend on skin cooling for the battery.
I guess as it gets closer to production we will learn more.Okay, maybe I'm missing something, but it doesn't appear this is just blowing air under the truck. Figure 7 shows a pretty defined inlet and exhaust around the battery from the ventilation system. Surely that wouldn't just be air intakes to the outside air, right? Are you supposed to connect an air hose as well as the regular charger? Is the ventilation system the indoor cabin system, or some other system? So many questions...
Obviously the info in that blog post didnāt come from Rivian (maybe itās in the actual patent filing?), but it does say itās blowing the air under your truck.Okay, maybe I'm missing something, but it doesn't appear this is just blowing air under the truck. Figure 7 shows a pretty defined inlet and exhaust around the battery from the ventilation system. Surely that wouldn't just be air intakes to the outside air, right? Are you supposed to connect an air hose as well as the regular charger? Is the ventilation system the indoor cabin system, or some other system? So many questions...
Do the air vents/ shutters on the front of the truck lead to the battery? Maybe as you said there would be a way to direct that cooled air through there to accomplish what they are trying to do.Best of all, this system could easily integrate into any of Rivianās current vehicles because it requires no physical alteration of the battery temperature management system. As seen in the diagram below, the vehicleās battery management system would work to maintain the batteryās internal temp, but instead of taking in only outside air, the air being pushed underneath the truck would be pre-conditioned by the charger.
I didn't look at the rest of the patent but the photo on teslarati shows both a "remote airflow station" and a separate "remote coolant flow station". I'm guessing the patent is just covering their bases on different ways of doing the same task. A battery could be air cooled or it could be liquid cooled. You could have an industrial sized liquid coolant chiller that would be way more capable of heat load exchange than you'd want on a vehicle that doesn't need to exchange as much heat under standard operation.Okay, maybe I'm missing something, but it doesn't appear this is just blowing air under the truck. Figure 7 shows a pretty defined inlet and exhaust around the battery from the ventilation system. Surely that wouldn't just be air intakes to the outside air, right? Are you supposed to connect an air hose as well as the regular charger? Is the ventilation system the indoor cabin system, or some other system? So many questions...
From the actual patent document:I didn't look at the rest of the patent but the photo on teslarati shows both a "remote airflow station" and a separate "remote coolant flow station". I'm guessing the patent is just covering their bases on different ways of doing the same task. A battery could be air cooled or it could be liquid cooled. You could have an industrial sized liquid coolant chiller that would be way more capable of heat load exchange than you'd want on a vehicle that doesn't need to exchange as much heat under standard operation.
Maybe this is why the RAN stations are all sideways, to leave room for these units.ABSTRACT
A charging station assembly capable of generating and delivering a conditioned airflow while charging a battery of a vehicle. The temperature and flow rate of this conditioned airflow may be controlled based on the ambient conditions and battery status. The conditioned airflow may be directed toward an outside heat exchanger of a refrigerant system of the vehicle to enhance capacity. The conditioned airflow may also be routed to a battery pack for direct cooling or heating through additional ventilation system. In hot ambient conditions, the charging station provides cool air to facilitate battery cooling. In cold ambient conditions, the charging station provides hot air to facilitate battery heating. This charging station assembly shifts the load from the vehicle refrigerant system to the charging system, thereby improving battery thermal management capability, while eliminating the need for an oversized refrigerant system.
āDose was the days, E-ditāOr a charging station attendant plugging in coolant hoses
I just had to find that comercial lol:āDose was the days, E-ditā
Awesome!I just had to find that comercial lol:
