jeeden
Jeremy
Northern VA
Project Manager
Getting excited for my R1S and it will be the first EV I have. I'm torn on if I should hardwire (for max amps) a charger in the garage or outside around the corner. It really depends on if the R1S will fit in my garage or not.
Anyway, I tend to have a lot of outdoor tools lining the sides of my garage and a large wood set of shelves in the back so looking for inspiration on clean installs for charges in the garage and thought it would be great to have a compilation of them here. Doesn't matter if it is the rivian charger, plug in, hard wired, etc.
astonius
Cars
Still need to complete the finish work, but here's mine. 2x Wallbox Pulsar Plus 48A in a load-sharing configuration. Allows each individual unit to reach a 48A peak or divvy a total of 48A between the two. I was a bit irked to discover mid-way through the install the additional sub-panel between the two wasn't necessary, but it works.
Rivian R1T R1S Show off your Level 2 Home Charger installs here 4D7872AA-ECD4-463E-AB9B-23D8D0D10D27_1_105_c
jeeden
jeeden
Jeremy
Northern VA
Project Manager
My garage is a disaster but we have two chargers on either side of the garage, one 30 amp for the BMW i3 and the 60 amp Rivian that is hard-wired.
Cool that you have 2. They don't talk to each other right? I will probably cut our drywall and fish the wire to avoid dealing with all the conduit.
jeeden
jeeden
Jeremy
Northern VA
Project Manager
I see a lot of good reviews on the Austel and wall box I have a rivian on my config but thing I'll get one of those two instead for the extra features.
Sgt Beavis
Rick
Overpaid Computer Nerd
Not a lot to show off. I need some Rivian wall art. I also need to relocate my clamps.
Rivian R1T R1S Show off your Level 2 Home Charger installs here B4E6FC10-A9BF-41AA-B0EF-3AC5AEE37ABA
DaveA
Doesn’t get any more simple or minimalist than this. ?. I’m sure this is as clean as his new home will ever be.
Rivian R1T R1S Show off your Level 2 Home Charger installs here CF234637-7E04-4F63-AD30-486E14CCC34F
Runs_4_beer
Carl
Reno
BMW i3, Audi Q7, F350
They do not talk to each other. They go into a 100 amp sub panel that also has some household circuits. With both running they could pop the 100 amp circuit, but I try to stagger the charging.
jeeden
jeeden
Jeremy
Northern VA
Project Manager
Could use some tie wraps on that opener cord amiright?
DaveA
JerseyGreens
NJ
2023 R1S ADV
CAT Property Underwriter
I'm glad you posted this OP!
Just found out my utility company offers to cover the labor up to $1,500 for the install of an EV charger but I have to pick a juicebox or charge point flex...
If you guys had $1,500 to spend on an install with only a 25 foot run from the basement to the garage (adjacent) what would be on your wishlist?
I should clarify I still pay for the charger out of pocket but the install is covered. I got a quote for 750 for a 14-50 outlet but I'm thinking go big or go home...since I have "money" to spend. Should I put a sub panel in the garage, or any other random upgrades?
astonius
Cars
Juicebox if you ever plan on load-sharing, otherwise ChargePoint Flex.
R1Sky Business
Both excellent options
JerseyGreens
NJ
2023 R1S ADV
I'm leaning charge point flex. For now I'll have my R1S but my wife still has an ICE. Even when/if she goes electric I doubt we will both need to charge at the same time. I WFH and barely put miles on my car.
