0_r1t_0
2022 Rivian R1T Launch Edition Green
My 2022 R1T Launch Edition got a recent upgrade!
Originally I had the factory 275/55/21 road tires and needed to go...
So I sold those and upgraded to the specs below:
I went ahead and installed 275/65/20 BFG KO3 all terrain tires.
These are BFG's all new all terrain platform.
More aggressive sidewall (similar to KM3) with a slightly different
tread pattern from the previous KO2s.
I also paired the KO3s with the Rivian specific Black Rhino Voltaic forged wheels
Specs: 20x8.5 / +35mm offset / 32.4 lbs (8lbs lighter than factory) / Gun metal finish
They drive very smooth and not very loud. Im used to these types of tires on other trucks/Jeeps so
they seem quiet to me.
Rivian has calibrated the Rivian to accept the new 275/65/20 size.
Some Rivian already come standard with this size.
One downside, is if you are driving in conserve mode (low), you may experience rubbing over bumps.
There is only about a finger worth of room from the top of the tire to the arch. I never have the Rivian
in conserve mode even on the highway. Always All purpose mode for everyday driving.
Rivian R1T R1S BFG K03 tires / Black Rhino Voltaic wheels installed on Rivian R1T Rivian Voltaic wheels.JPG
Rivian R1T R1S BFG K03 tires / Black Rhino Voltaic wheels installed on Rivian R1T 20240109_194552
moosehead
Those BR's are bad azz. Nicely done.
marcbenton
Marc
Spanish Springs, NV
Rivian R1T, Model Y
Where did you order everything? This is the EXACT set up I am looking for order.
Looks amazing!
Reactions: Jac
rmalzo
Ray
Prescott Az
2022 f1t
Looks like offset is wrong and stick outside of fenders. Is that correct? Photos?
Glongo
Glen
Mammoth Lakes, CA
R1S; Cayenne Hybrid; Sprinter
Homebuilding
Nice set up 0-r1t-0. Thanks for the report!
0_r1t_0
0_r1t_0
I ordered wheels from Tire Rack. And the tires from Discount to get the lifetime warranty certs.
0_r1t_0
0_r1t_0
The factory offset was +45mm if I remember correctly. These new wheels are +35mm offset so the sidewalls sit flush with the face of the fenders front and rear. It's the perfect offset for the truck.
Rivian partnered with BR to make these specifically for the Rivians.
rmalzo
Ray
Prescott Az
2022 f1t
Can you post a side view?
